Tire questions
JayPo
JayPo
Somewhat Well-Known Member
11,324
110,272
Tennessee
I’m still learning all this off road stuff and I’m curious if I run helium in my tires will my buggy just float across the mud holes?
Also using helium in my tires should help when rock climbing because the tires should just float up and over the rocks, right?
I’d appreciate any and all input on this subject.
Thanks.
If you're gonna go the floating tire route, use hydrogen instead as it is even lighter than helium.
67,531
Thanks.
What oil are you running is just as important. Also what did you gap your plugs at after you added helium?
Ridinfool
Ridinfool
36,145
386,041
Western North Carolina
I went with a 2 stroke oil, I figured it felt the lightest,
As far as spark plug gag… I didn’t measure Ed Zackery but it appears to be about 12-14” maybe more…
108,989
Plug gap? As in Mind the gap!🤔
IMG 6069
67,531
Right on, right on. I'm considering doing this and looking for all the info I can. I was also considering running my tires inside out, should last twice as long.
Ridinfool
Ridinfool
36,145
386,041
Don’t forget to rotate the tires perpendicular to the rotation of the axel shafts! You should consider getting omnidirectional tires and rims!
I think that’s a different thread…
Although, I was checking out the ball part on the Bosses Dyson earlier…
Ridinfool
Ridinfool
36,145
386,041
Running the tires inside out? 🤔…
Before or after you wear the tread on the outside?
