P700 To much dust for happy wife
calvin17
calvin17
17
41
Sturgis Sd
wife loves our 700-4 but hates the dust. We live in South Dakota after a ride we look like a couple of people from a wagon train. Can you guys help me out? Calvin
Jshell3
Yes. Windshield is the culprit, if you can remove it and still be comfortable, that will solve your dust problem (unless you follow too closely behind me!)
Reactions: Nipper and sharp
wyo700
wyo700
413
210
If you have a windshield you have to get the back panel. Easily cuts dust in half if not more.
Arizona
Arizona
102
201
Casa Grande & Show Low Arizona
A windshield that seals to the hood helps cause the vacuum that makes air & dust swirl back around into the cab. On my half windshields I make sure there is at least a 1/4" gap between the bottom of the windshield and the hood, it really helps reduce the vacuum effect because if some air can pass under, then it lessens the vacuum.
Reactions: the-op and sharp
jawquin
jawquin
299
652
Indiana
Found it. Now look at the seats where we sit. My butt is bigger than hers. I can relate to what calvin17 is up against. Put in a mid panel and the wife will be happy. On another note.....Think about how hard the air filter has to work. :eek:
DirtyGettingFishing  20140818 174111
N
Nipper
84
136
Oklahoma
There are some posts on here about vents some have installed in the roof. Havent heard how well they work but thinking of trying it for the winter months here as it dry here then sometimes too. Using mine to haul hay and feed wrecks everthing in the cab from that stuff swirling.
Sent from my SAMSUNG-SM-G930A using Tapatalk
63,408
Calvin,
the first few replies have your solution. A backdrop will greatly help and raising the windshield or installing vents is a second best.
@rocmar,
your post has brought no answers to the OP's questions. Please keep things on track.
- Will reopen post once I clean up all this.
Lynn1130
Lynn1130
126
171
Phoenix, AZ
I have the honda windshield that allow me to open in some. I also have the back panel but dust happens and so we use a good set of goggles and the Wolfsnout.
Reactions: trigger and swsebek
