1border4manu
How often should I be greasing the bearings on the trailer used to haul Little Red around? I know to much is just as bad as not enough. Thanks for the help.
How often should I be greasing the bearings on the trailer used to haul Little Red around? I know to much is just as bad as not enough. Thanks for the help.View attachment 159587
I couldn't tell, but it looks like you have the bearing buddies hubs caps? That's good! Keep in mind that the seals are designed to keep grease in not water out, never submerge a wheel long enough to launch a boat with a warm wheel, it will vacuum water into the bearings. I've got 16'000 miles on my bearings and going strong. I have a digital thermometer and shoot the wheels, the brake wheels will be a little warmer than the other axel wheels, happy travels!How often should I be greasing the bearings on the trailer used to haul Little Red around? I know to much is just as bad as not enough. Thanks for the help.View attachment 159587
That reminds me... I’ve been running my gashed tire from CO and it’s finally got to the point where the plugs won’t hold air longer than a few minutes. So we took it down to the dock and jumped on the boat yesterday. Had my portable air tank and put some air in the tire and headed back to the shop. I was a couple hundred yards from the shop when it went real flat. It pissed me off so I decided to put the spare on. And OMG... I was amazed at how much tire heat was created in such a short distance.I have some of these in my tow vehicle.everytime I stop for fuel I compair tire and bearing temps.
Very easy to tell if you have a low tire also.
Yup.. I put a hand on mine at every gas stop.Also depends if a trailer is used on salt roads. By habit i always stop in the first 20 miles and feel the hubs for heat. Its easy to tell when they are starting to go if you pay attention.
Don't forget to rotate the tires from side to side to even out the ware pattern. You rotate your car tires for the same reason.Thanks for all the responses. I knew I would find the answer here.
