Multi Trailer jack foot extension
11,321
84,118
Anyone have experience with the Fastway Flip foot or the Husky Brute Superfoot? Interesting products to save on jack cranking for about $35. Lots of you tube videos. Kinda leaning towards the Husky, seems faster and # rated higher.
5EF08F2E DEA9 4CF5 9AA5 17D9DF859A06 41C533C4 CCCE 4462 A614 294FA4ECD7C3
Reactions: BWAF and trigger
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,762
183,062
Grand Junction, CO
View attachment 89406 View attachment 89413
Either one should do the job, After a lot of thinking a pondering over the Fastway or Superfoot I got the Superfoot and I am pleased with it and it seems to be more solid.
Reactions: BWAF and Mudder
11,321
84,118
Either one should do the job, After a lot of thinking a pondering over the Fastway or Superfoot I go the Superfoot and I am pleased with it and it seems to be more solid.
Could a hitch pin be used on the Husky for removal when parked at the trailhead?
Reactions: BWAF
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
biggest thing for you to make you decision is how much minimum ground clearance will you have one look a good bit longer than the other one
Reactions: JTW and BWAF
11,321
84,118
Also like how the foot on the Husky can be removed, can change out between wheel or sand foot. Smart idea on either, wish I had the patent.
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,762
183,062
Grand Junction, CO
If you mean a hitch pin the remove the whole foot then you could use a hitch pin and depending the the tongue weight of your trailer is is strong enough to support the weight. Mine is on my toy hauler that has a 1500 lb. tongue weight so I want to stick with the heavy bolts.
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,762
183,062
Grand Junction, CO
Yes, the foot is attached with a hitch pin and can be quickly removed and your wheel put on. The reason for the hitch pin at the bottom is because there is less motion than at the top of the foot where it bolts to the tongue jack.
Reactions: BWAF
