Talon Trailer size?
PaulF
PaulF
1,462
4,816
A stock R will fit on a 6X12 with a tailgate. It will fit on a 6X10 without a tailgate. That catalog only says 74 inches wide but does not say how long. It has a tailgate/ramp so as long as it is at least 12 feet, you will be OK.
jcarr343
24
21
florida
Hard to tell from the spec sheet, but it is a 10' trailer with a lift gate.
PaulF
PaulF
1,462
4,816
Won't fit an R, it is a couple inches too short. You need something at least 10' 6" for the R and that is cutting it close. I suggest a 12'.
Reactions: seig
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
I have an aluma 7712 and I havent had any issue with it at all
Reactions: seig and Fyathyrio
Anyone else with tilt trailer experience?
Yes, and it was a piece of crap, I left it in @Tramguage1 ‘s yard and went home with a new 14’ tandem with brakes. The only way I could load up on the tilt was to back on to it, the weight is greater to the rear of the sxs and it wouldn’t return to horizontal if I pulled on, shrug.....
Reactions: seig
F
Fyathyrio
245
675
I have the same trailer, I love mine. The extra width allows for easy tie-down and getting in/out the Talon.
Reactions: seig
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
ive only had mine for about 2 weeks, trying to decide on what type of straps i want to use. not sure if i want to cut a hole in a 3k trailer
Reactions: seig
F
Fyathyrio
245
675
I went with these, there's four to the set, they have keepers on the hooks to prevent coming off if the suspension takes a big bounce & slacks the strap, they come with double loop straps to wrap around frame or trailer as needed, and even include velcro straps to wrap up the free end of the tie down and keep it from flapping in the wind.
Reactions: seig and CMB
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
I like those. thanks for the info
Reactions: seig
Rubin
Rubin
45
170
Canada
Got a 14x83 fits perfectly and used the e track tie down system best ever.
D3BBF3E6 2793 4D4E 8BF2 BE1509309709 DA0C0C87 2669 413E 81BA DAD2AFFDBE88
Raynman
Raynman
Sudo Flotation device inspector
5,943
70,123
Thumb area, Michigan
I have a 7 x12 aluminum trailer with bi-fold ramp, always go bigger than you think you need.
Reactions: Montecresto
