P1000 Transmission issues
115,791
First off welcome and..
Pics Or It Didnt Happen!
second, its a 17’, have u had the clutch update before we go any further?
G
Gulk1983
5
Texas
Have not had the update it is only used at my deer lease are you talking about the oiling issue they have
Reactions: Lady01
115,791
Nope. Full update. Ill look for the thread to help u identify it. If its not done, u should do it. Your linkage could be off as well
Reactions: Lady01
G
Gulk1983
5
Texas
This happened out of the blue no warning bike was running great got in it the next morning shift into reverse and all I got was some loud clicking like it jumping out of reverse all forward gears work no other issues
115,791
This is it. It was a recal thats expired but if it hasn't been done id suggest it.
115,791
This too will help
115,791
And starting at post #13 will be a good start also. Let us know what you find
slowdryrider
slowdryrider
572
778
Canada
The reverse is accomplished by shifting in the sub trans. It's quite possible that the linkage needs adjusting. Check to make sure the main cable that goes from the gear shifter down to the sub trans is moving the shift lever enough , it could need to be adjusted. Also it's a possibility that the shifter fork has gotten bent inside the sub trans.
P1K5Dave
P1K5Dave
2,245
8,427
Petoskey, MI
Are you planning to diy it, ot taking it in to a shop? Stop back and give us a follow-up.
Reactions: Lady01
