P1000 Transmission Rattle
russknight
russknight
1,916
7,542
Perry Florida
My 2016 1000-3 has a "rattle" in the higher gears when driving slow under load. It seems to be more noticeable when in manual mode in 5th and 6th gears on pavement just lugging along. When I accelerate and rpm's come up, the rattle goes away as the normal transmission whine becomes prominent. Anyone else notice a sound like that? A passenger asked recently if the valves were rattling.
Russ989
Russ989
22,569
146,535
I just bought a 2019 in November and the tranny does seem to be fairly noisy. I’ve noticed the rattle sound you described but it seems to be normal.
russknight
russknight
1,916
7,542
Perry Florida
Yeah, it's normal. It's the slack in the front drive shaft when it's not engaged. When you run it 4WD, you'll notice the rattle goes away.
I'm not sure that is the issue. Sounds like it's coming from the rear section of the engine. Hard to tell.
Reactions: Lady01
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Sound like this?
Mine turned out to be front driveshaft. Only noticed on pavement above around 30mph and under load (accelerating or going uphill)
Reactions: Lady01
rickoshea
mine started doing it around the 650 mile mark.took it into the shop and was told not to worry about it? at least it's documented if it fails later.mine almost sounds like the exhaust is rattling,but it still pulls fine under acceleration.i run mine like i stole it so if it is going to fail it'll happen soon.
Chmathu89
22
29
St. Anne, Il
Sound like this?
Mine makes the exact same noise and I've posted on the forum asking about it and got no answers. Did you replace the front driveshaft or is it something not to worry about? I had my skid plates off and wiggled the drive shaft and it seemed to have more play than I thought it should have and figured that's where the rattle was coming from.
Reactions: Lady01
russknight
russknight
1,916
7,542
Perry Florida
That's what mine sounds like too.
Reactions: Lady01
JenElio
JenElio
64,490
604,508
Loxahatchee, florida
Does it sound a little like marbles rattling around the heat shields? Cause I've noticed something similar too
Reactions: Lady01 and wm4u
Chmathu89
22
29
St. Anne, Il
Yes mine resembles the noise you described. I just don't know if its a big deal and needs to be brought to the dealer while it's under warranty.
Reactions: Lady01
JenElio
JenElio
64,490
604,508
I started to notice it not long ago. It only has about 200 miles on it too. I might bring it in one of these days just in case. Like @rickoshea said, if they say it's fine and it fails later on, it'll b on record.
Reactions: Lady01
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
I took it to the dealer and they replaced it under warranty. They had the same thoughts that it had more play then it should have.
Reactions: Lady01 and JenElio
LIVINTALL
LIVINTALL
54
151
AZ
Just looking through the forum and saw this thread. Could what you are hearing be engine ping? High load situations is a good recipe for pinging and can sometimes sound like marbles in a tin can.
Reactions: Lady01
wojtalon
wojtalon
5
Golden, Colorado
I have the same rattling noise and it's driving me bonkers. Have a listen to the video to see if you might have more ideas to help identify the noise.
If you watch the suspension move with the noise, it feels like it's in the suspension.
W
wm4u
5
12
Maine
Did you ever get any answers on this? My 2021 with 200 miles does exactly what you’re describing. Sounds like marbles in the rear when in a higher gear below 3k rpm
Reactions: Lady01
russknight
russknight
1,916
7,542
Perry Florida
Nope, no idea. It's still doing it. It might be the infamous chain tensioner.
Reactions: Lady01
