P1000m5 Traveller II
2016 Honda Pioneer 1000-5 Deluxe
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Joeymt33, you have good taste as every project has been installed with a level of quality I hold my self to! I haven't done a lot to mine as of yet but, I'm no stranger to custom one of a kind mods, my ranger crew is one of a kind. One thing I haven't seen yet is a multi mount winch set up for the P1K5D. Any plans to add one to your build?
Reactions: JTW
I have thought about it but I've done fine with out for years. If I ride alone, it may be a good idea.
I guess when I get itching to find something new to add, I may give it a shot. I've been hesitant to use the hitch as a mounting location as I'm worried about its strength in a pull that's anything but straight.
I did add some permanent mounted tow straps to the rear. Have you checked those out?
Eltobgi
Eltobgi
4,599
15,187
North Dakota
I have. Great Idea! I will most likely borrow that idea from you. lol I've hesitated to ride alone in the past because of the high water table in the Turtle Mountains, but when I did the multi mount winch set up definitely came in handy. Now with the confidence I have based on Honda Reputation, I'm sure I will find myself riding alone more frequently. Nice work on the build! Its one of a kind!
Reactions: joeymt33
dale5740
dale5740
886
417
mt airy md
its guys like joey that make this site great thats for sure!!
Thank you guys for the kind words. My machine may be considered a beast, but it got stopped dead in its tracks today. This little bitty mudhole in the trail looks harmless, it was not much longer than the pioneer.
7d74dbc72d967b257cc2b8df22735d77
Eltobgi
Eltobgi
4,599
15,187
North Dakota
That's what the shackles are for
Reactions: joeymt33
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Wow I just had dejavu lmao. Those small mudhole can be very deceiving. I know lol
Reactions: Tot and joeymt33
whayden2003
whayden2003
164
291
Slaughter,LA
Sorry if this has been either asked or stated already. Is that the Two piece hard coat windshield if so how is it holding up. Really wanting the ability to open it for air flow but I am torn between it and the real glass one for the durability. I know it's Apple to oranges.
Reactions: dale5740
I like it OK, but I don't think it's worth the price.
One thing to consider, the top piece is hardcoat and the bottom piece is not. In my opinion, Honda screwed us on this one. They should've called it a two-piece windshield and top piece hardcoated.
With that said, here are my observations:
1. When you get around 35-40 miles an hour and faster it will start vibrating violently if you have it open. Ask @ohanacreek.
2. It needs to open more than 4 inches in my opinion.
3. When closed, it does a good job of stopping pretty much all airflow coming through and hitting you.
4. It is very easily installed and removed for when you don't want it.
5. The hardcoat seems to be very scratch resistant. I use common sense and rinse off the windshield with water first and then I wipe it. Last weekend while riding, it got very muddy and I rinsed it with a bottle of water and then wiped it off with a towel and there are no scratches on it.
Super ATV now has a windshield that will open all the way up but it is still plastic.
Joe
Reactions: Dp5hunter
whayden2003
whayden2003
164
291
Slaughter,LA
I saw that one from super atv. Don't like it because it doesn't seem to wrap around the roll cage. Does it rattle to bad when close and driving.
It does rattle when closed, but that could be fixed with a gasket material along the rim. It only rattles when going over rough terrain at a fairly high speed.
Reactions: DGann
If I am this deep into the pioneer, any other modifications I should make?
53f83849101d27a26aca558b9defe26e
8bb8194ee1b9a43bc7661a27e8b6cbe7
Right now I am going to do some sound deadening material.
Sent from my iPhone 10s
Reactions: pct
I have almost 500 miles now on the pioneer. I thought I would check the air filter after riding at royal blue. It doesn't look too bad.
Af811eaacac21f700d899453c6d8de4a
While in here, I am also making sure everything is watertight, hose clamps are tight, checking all the ground wires, and changing the oil.
Reactions: Eltobgi
whayden2003
whayden2003
164
291
Slaughter,LA
I was wondering to myself over the weekend how much that filter was. Fixing to check.
CashMoney
CashMoney
329
211
Reno, NV
www.SRTNV.com
if you got that much tore apart how hard would it be to run some hoses in case you ever wanted a heater haha. Might be a good time to run any extra wires you might want for future stuff
Extra wires! I didn't think of that. I've got a switch for rock lights but have no rock lights installed.
Thank you!
Similar threads
Hometeam
Replies
Views
2K
Hometeam
