I will install the circuit breaker at the battery since this is a long run of heavy gauge #4 wire. I guess it could trip to 250 amp circuit breaker first which that'll be fine. So one of the three things will happen first. I just hope the circuit breaker trips or the winch stalls and not any breakage. BUT, I would rather test it in a controlled environment when there's no one around to get hurt.
I guess I could video that for you just in case.
Next was to clock the terminals so there's no clearance issues at the frame. I wasn't real sure what I was doing here as I've never done that before and I don't have any instructions. But I just took the motor off and turn the whole thing and put it back on
Should be because this setup bolts through the receiver and to the suspension. I'd sure see those pos 4 bolts into the bottom of the winch sheer before the others.I tripped my 300amp as my winch stalled on 1st layer. So I am guessing the 250 should trip earlier.
Hope the bolts are up for the task.
I've also got a 300 amp circuit breaker. Maybe I should use it instead.
As much as you get stuck.. you need a rear winch!
Wow that looks beefy! And beefy is good! I gotta break out the microscope next time I see this thing lol. I'm still dead set on a rear winch bumper combo. Everything is figured out except making it strong (minor detail) lol.This is as far as I got yesterday. Hopefully I'll finish it up in the next few days.
Once I get the lower mount made, I'll put it in the sandblaster and clean it up and then depending on how I feel, I'll either powder coat it or rattle can it.
Then I still need to run the wires and mount the solenoid. This winch will only get a wireless remote for now.
After everything is finished, the first thing I'm gonna do is go out and test it. I will chain the front bumper to a tree and then hook the rear winch to another tree with the snatch block and see if I can stall the winch or rip them off. One of them will happen first and I got to find out before it fails in the woods.
Or to pull a tire out of your bodywork if you snap a control arm mount. Just saying.It can also be used to pull you back to tires down. Remember that.....tires down. You keep repeating it over and over.
So the whole winch mount can be removed with three bolts and just a couple minutes. No permanent welding to the Honda, only some minor cutting.
I know I'm moving a snails pace compared to what I'd like to do but I'll eventually get it all done.
Another positive about this mod is that the hitch just because a lot stronger for tongue weight and side load. I'm happy about that as I'll be using a clevis on a hitch for tying down and towing other vehicles.
CP: This group looked for anything rough and had a great time. It wasn't all about who was the best or correct line just some good ol boys with a beer and a 4wd.
The expensive part is changing muffler out. Winch won't fit with factory unit installed:-(Do you have a cost set yet for these mounts? And when will they be available?
You have the perfect bumper for a rear winch. Even already has mount holes drilled. Just need a bumper mount to match.Do you have a cost set yet for these mounts? And when will they be available?
