P1000m5 Traveller II
2016 Honda Pioneer 1000-5 Deluxe
Eltobgi
Eltobgi
4,599
15,187
North Dakota
The passenger side is hot because the exhaust is on the passenger side. I would wrap it with header wrap if I thought it would last a while and not rust out.
Anyone have thoughts one the rust issue using the wrap? Can a guy paint the pipes first to prevent rust?
This is a link to a potential solution. I've heard it works but have never tried it myself.
Rust Proofing - Burn Your Headers - Circle Track Magazine
Reactions: joeymt33
Springer
Springer
312
234
If I am this deep into the pioneer, any other modifications I should make?
Right now I am going to do some sound deadening material.
Sent from my iPhone 10s
Hey @joeymt33 i am thinking of doing some sound deadening as well. I can not stand the whine I hear from the motor. While you are in there can you tell me if you get a high pitched whine from the alternator area that changes in pitch with rpm increases ? Also, I was thinking of using Dynamat Extreme. Any thoughts on that?
Thanks
Reactions: Nappy33
Thanks
Not sure of the source of the whine. The sound deadening didn't seem to help much. I guess you're right, it could be the alternator.
I haven't ridden long enough to see if it helped with heat.
Reactions: DGann
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
We are gonna remedy that soon as you get some time off during the week lol. There's still a couple trails we haven't been on yet.
Reactions: DGann and joeymt33
dale5740
dale5740
886
417
mt airy md
I don't think rust would be as big as an issue as u think do to moisture wont be there do to heat running through it!!
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Rust wouldn't be a constant worry. I ran header wrap on my dragbike for years and it was never really a problem. Every winter when I freshened it up I'd remove wrap, sand off surface rust, and respray. It's caused by condensation from putting them through so many heat cycles. I plan to use it on mine whenever I can find time to install it.
I've heard a lot of people say that pipes will crack or rust but my old P700 has been wrapped a while now and had no issues.
I just did a quick google search for "header wrap rust" and found some nasty pics of broken and rusted out pipes.
I'm not sure what to think...
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I'd be willing to bet those rusted pipes belonged to owners who installed it and forgot about it. A little preventative maintenance every once in a while and you'd be good
I may remove my pipes
If it's not too hard. I could powder coat them as I have on hand some high temp paint. That would probably help a lot.
Reactions: dotman1
dale5740
dale5740
886
417
mt airy md
If it's not too hard. I could powder cost them as I have on hand some high temp paint. That would probably help a lot.
If u are going to take them off then get them jet hot coated or ceramic or something of that nature!! what about taking the wrap off after a year and checking on it? paint area well with Hight temp paint like for a grill or header pipe paint then put wrap on that section u painted and check on it after a year. what I have done in the past was used header wrap and hose clamps on the ends to hold it from coming apart. I have also made aluminum heat shield in the past and heard that on with stainless hose clamps
Reactions: joeymt33
AKRider
AKRider
1,402
3,225
Palmer, Alaska
RMATV will not let you search for OEM Honda SXS parts, I tried the part # 08U70-HL3-A40 Still had no luck, when you have time can you check your order email from them for the RMATV item number they use? Much appreciated.
Your build is coming along quite nicely, keep up the good work.
I didn't see an answer for this and was looking them up myself just now. Here's RMATV's part number - 1678290001
Reactions: joeymt33
AKRider
AKRider
1,402
3,225
Palmer, Alaska
Here's the pics for the front diff
OEM vent
96ae04194428f18086fd87edfd5ec593
Here it is installed
Eb97535f6a930a78212f82a42548e8f8
Another pic from a different angle
7d81e019c75c850da3e39d34950a80a0
The diffs had a smaller nipple sticking out so I had to reduce the tube size like this
31c0f35b76c67e6df1102c63368a1d32
Is the reduction on this 1/4" to 1/8"? Nice work, BTW.
Honestly, I don't know. I ad this stuff in the shop for small engine repair.
I think I've got some tubing left so I can check that in a little while.
Sent from my iPad 7G
AKRider
AKRider
1,402
3,225
Palmer, Alaska
No worries or hurry. I was just curious. I'm researching what I need to do this and found different ID's on the bellows. I'm don't have access to my machine right now so I can't look at it. I think the sub-trans is a 1/4" nipple and the diff's are 1/8", but I'm not sure. I assume you used the same bellows on all three.
I did use the same bellows everywhere.
The size of the tubing is not listed but here's a picture of it and the connectors and clamps I use. I buy all this stuff at my local O'Reillys auto parts
Eb930502e51a7e414be15c7b1ecd6d47
69ad935cd4d59779e1322c73c6c3539b
Reactions: Dp5hunter
AKRider
AKRider
1,402
3,225
Palmer, Alaska
Awesome. Thank you. I have a O'Reilly's just down the road from my house.
One more question... is that tubing safe for fuel?
Sent from my SAMSUNG-SM-G870A using Tapatalk
I'm not really sure. I usually use Tygon fuel line so I'm not sure what this is.
I think it's engine vacuum hose
I will like to report back that after riding around, I cannot see any significant change in the noise level.
I will probably have to ride for a longer duration to be able to test the reduction of heat.
After today's riding with @Delton, we could tell a significant different in heat on the plastic shield between the seat bottom and seat back. Mine was barely warm and his was too hot to hold your hand on it. His daughter was complaining like my boy used to do. Now I've got the additional heat shield from Bayouownbeer installed this evening and I will try it out on the next ride.
Reactions: Dp5hunter and Tot
Similar threads
Hometeam
Replies
Views
2K
Hometeam
