P500 Trouble - electrical
Mudder
Mudder
NTC Ambassador of Walls
11,691
88,486
After a night of full battery charge, still no start with rapid cycle flashing and associated loud clicking from fuse box. Isolated to this relay removed from cluster of four. Any ideas or knowledge on this relay? I have removed and cleaned battery contacts as well as the OEM frame ground connection. Before it died, I idled very rough.
17210003 73C2 48E6 9BC2 76EE9E9B3155 29B9181F 0729 4426 B7AE 4DE72B23D95E
Neohio
Neohio
Beast of the East
17,759
85,632
Painesville Ohio
Is there a diagram on the cover that states what the relay is for?
Can you swap with another relay and get it to start?
Looks like a basic relay. Should be able to walk into a parts store or Honda car dealer for a replacement.
Mudder
Mudder
11,691
88,486
Swapped relay in spot, dash display normal then, but no start. Cover only describes small fuses.
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,790
183,384
Grand Junction, CO
I had something like that happen to my Rincon once, was driving me nuts and it turned out to be a bad battery.
Reactions: Mudder
Mudder
Mudder
11,691
88,486
13.96 volts everywhere after overnight charge. 2 yrs, 9 months on battery.
Mudder
Mudder
11,691
88,486
Thinking battery now. Only 5.5 volts across terminals after sitting a while. Time to search posts for best replacement battery as the first effort.
Reactions: Wallace
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,790
183,384
Grand Junction, CO
I have also heard clicking on someones engine once and it turned out it was hydrolocked.
snakeriver
272
596
Clarkston Wa
But what are the load numbers on the battery. You can have adequate voltage on a meter but not under a load.
Mudder
Mudder
11,691
88,486
Update, new battery fixed it, (who said money doesn’t bring happiness?), but strange that the dash lights came on upon installation without key on, swapped relay positions and started it a few times, then returned relays to original slots and all now working OK. Go figure. At least the trip to the Honda dealer gave me a chance to sit in a Talon, and to see the new P500 green color.
70Bones
70Bones
888
3,779
New Brunswick Canada
Batteries can fool ya, they can hold voltage but may not have near enough current available to do any more than operate the starter relay. Glad you got it figured out! Did you see any shi... moose brown at the dealer??
Mudder
Mudder
11,691
88,486
No moose brown, just green, white and camo. Hard to remember when mine was so clean. The new Honda Monkey reminded me of the 1970s. The name was surprising.
6E7520CC 5D4F 41E7 90E2 22DD9E7C40C9
