P500 Trouble shifting
DeanD1968
WV
When I try and manually shift it wont do anything, the instrument panel just blinks on whatever gear it is in. Any ideas what it can be?
  • Wow
Reactions: TxDoc and Smitty335
Mudder
Mudder
NTC Ambassador of Walls
11,692
88,500
Just the quick and easy troubleshooting first.
Does the battery crank the engine ok? These are sensitive to voltage drops.
Is the oil level full?
Try the shift tool and rock it in case it is stuck between gears.
Has the clutch been adjusted?
There have been posts about the shift motor by @HondaTech ; but does it shift in auto?
Try a search in the meantime.
Good luck.
Reactions: trigger
Mudder
Mudder
11,692
88,500
Did you figure it out?
Reactions: futzin
