Kicking around the idea of a dual battery setup. I would have minimal accessories on the secondary battery; probs just a winch and a couple of lights on the top of my cab.
Can I use the unused ground that Honda provides that's taped up by the main battery to go to the secondary battery negative? If not, is it just a ground from one neg post to the other on the batts?
Where do I go with the small ground wire coming out of the isolator? Can it go to a battery ground or does it need to go somewhere else? If it can, which one? Does it matter?
Thanks
Thanks
