P500 turbo or nitrous
BeerMonkey
BeerMonkey
455
1,515
Mid TN
are you going to be doing head studs or anything to support the extra pressure?
Reactions: LandPioneer
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
no because im not going to be pushing it that much 7psi ish isnt close to the danger area now if i was saying psi in the 20s then id have to drop the compression ratio and stud the head and intake
I think @spifyd was only running 4-5psi on his 700.
Reactions: jak9922
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
I've done both...Nitrous on bikes and turbo on street car. Each has their pros and cons. Turbo would probably be more practical for a sxs imo. I liked the nitrous on my bike because it was the same every pass (great for bracket racing) plus you can tune on motor. But refilling bottles would be a pain for off-roading.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
like i was saying im not looking to make big numbers i just want more power for steep hills
266,545
Knowing the space constraints of a P500, getting all the plumbing of a turbo on that package will require some creativity. Not to mention with added power comes added heat, may require a larger radiator.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
i know all about piping with no room lol thank god for boxes full of pre bends lol
Screenshot 20170505 113703
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
Do you have a powercommander on the 500?
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
With the powercommander, you can hook a map sensor to it and retard the timing plus the auto tune option.
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
The timing stock is probably pretty low so you are probably fine.
Reactions: jak9922
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
i was going to go pc5 but dobeck gave me a discount i couldnt say no to... i figure i keep the wot afr high 10s -11 max with a step colder plug should be fine for low boost pressure
I wanna turbo the the 1k!
It'd be nice if there was a 3rd party kit or better yet a Honda signature accessory so it didn't void the warranty
Man that thing would run like a pack of dogs after a 3-legged cat.
I mean it's fun powersliding in 4WD as it is. I could only imagine the trouble I'd get into with a turbo.
BenBusenitz
Whitewater,KS
Still waiting for someone to turbo the P5....
RHB31 VZ21 turbo looks to be a perfect match. $140 on eBay. It’s tempting. That little 2 valve head just needs some boost to wake it up. Cheaper to do a turbo then a big bore. Also has way more cool factor.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
oil feed is where the problem is without building a stand alone oiling system
Reactions: Duckhunt
BenBusenitz
Whitewater,KS
Yes, that is a head scratcher. How did SpiffyD do it on his 700? From the pics, it looks like he pulls pressure off the head? Return can be dumped back into the crankcase anywhere. I just ordered a used oil filter cover for cheap on eBay...going to see about drilling and tapping a 1/8 npt fitting into it. Guys have done that to add an oil cooler on a 300ex or some of the utility models that didn't come with a cooler. There is a guy on youtube running a rhb31 diy turbojet with no oil by using ceramic bearings. Not sure how long they would hold up.
