Turbo Talon Owners - Would you do it all over again?
K
KenThompson
265
603
Mulino
Any chance anyone has the part numbers for this Donaldson/Top Spin Setup? I'm about ready to take the copper vitamin trying to clean the Jackson setup and there upgrade doesn't really make changing/cleaning the filter any easier. Thanks, I tried to lookup Donaldson 3" cartridges but it was rough.
The Donaldson I used was G082528 housing with P828889 filter, and the Top Spin pre-filter #H002853.
8222A317 82EE 4C1F A735 1C0248BD2134
Reactions: Drainbung
W
Wigglysqiggly
73
145
Phoenix
Got a question turbo support bolt keeps get loose and suggestions
Killer223
Killer223
266
535
My bracket kept getting loose, so I ended up fishplating and welding it. the support bolt had a nylock nut so it's not loosened on me.
Thesheep89
7
San Bernardino
Kraftwerks owner here. It's the way the talon should come from the factory. I think the car is perfect now. The most range is money now. It makes it a much more capable machine. In Sand mountain Utah it was worm to get the car up sand mountain and to the dunes on the backside. Now it's no problem. Highly recommend the Kraftwerks kit. High quality and worry every penny.
Reactions: Hometeam
Hometeam
Hometeam
937
3,689
Normal, IL
Did you do pistons or anything else with the Kraftworks kit? And who's tune are you running? I am debating on which kit to get...
SLOWPOKE693
SLOWPOKE693
1,600
6,051
Somewhere in Texas
The Kraftworks kit is good. Pair it up with PPEI tuning and you will have a ripper. As far as pistons go.... You might be able to get away with stock pistons for a while (or not) but I'd recommend swapping them out before they become a problem. Wossner pistons are very high quality and are reasonably priced. If I were in the market for a turbo kit, this is the route I'd take.
Reactions: Hometeam and CID
Hometeam
Hometeam
937
3,689
Normal, IL
Thanks! I do plan on doing pistons at the same time. The Kraftworks kit appears to be the way for me to go. Either kit I planned on doing a better intake and pistons which would require to get either one tuned. At that point the Kraftworks seems to be the better value. But I have zero first hand experience with either kit. I didn't want to get the Kraftworks if it wasn't a "better" kit, but just a cheaper kit. I like doing things one and done!)
W
Wigglysqiggly
73
145
Phoenix
I went with the jackson kit because more OEM plus look. Kraft seemed too wild looking and not even the can am has a big intercooler like that
