P1000 Turf mode
It's been doing it since I got it. I worked on it for 2 hours last night. Seamed like an easy fix but will not go into 2wd and light will not come on now. I lined everything up as manual and the Neohio shows in video still didn't work, played with it some more to see if I can get the tension correct with no resolve. And it's not even as hard as turning a wrench, you can turn those nuts with your fingers. I already have it going in Friday for the heat fix issue anyway.
Yeah.. if you're taking it in then let them mess with it. I'm an hour from a dealer so I tend to fix things myself. Also, if you become a lifetime member there might be service manual or 2. Well worth it!!!
ohiohunter
ohiohunter
103
141
Minerva Ohio
Yeah.. if you're taking it in then let them mess with it. I'm an hour from a dealer so I tend to fix things myself. Also, if you become a lifetime member ($40) you have access to the PDF of the service manual. Well worth it!!!
I'm about 15 minutes from my local Honda dealer but I don't take it there they are terrible, I take it to another one about an hour away. They are great to work with and always have time to answer any questions I have. Just like the heat issue, I called them up and they just said bring it in, not like some guys are getting told to wait for their letter to come.
I am life time member, but the manual didn't get me quite there. Had to back the center cable off 7 turns from manual to get it to work. Now it going in and out within a few feet of switching lever, I could probably get it even better with a little more time.
sargenthp
US
Just make sure you don't crank the cables too tight. I have seen a YouTube video where someone did that and caused the cog to pop off the fork. At that point the rear end needs to come apart.
Sent from my Moto G (5) Plus using Tapatalk
Reactions: joeymt33
chapee
Trussville, AL
I am a Lifetime Member - where do I find the PDF of the service manual for P1K?
Reactions: TimG
E
Ericthered
Eric The Red
271
522
Sparks, NV
The mistake some of you are having is from the manual. It states to put shift lever in 2 wd. That means 2WD LOCK, Once in this position follow directions to adjust cables. Once I figured it out my P1000 hasn't had ANY shift issues.
0860silverado
964
1,862
louisiana
And everyone keep in mind that as a safety measure, when you shift in to Park, by design, it locks the rear diff even if you are in turf mode! So if you jack up your rear wheels to turn them while making adjustments, make sure your trans is in neutral.
0860silverado
964
1,862
louisiana
IIRC, the way to think about cable adjustments is to remember the fact the cables don't "pull" the diff IN to lock. They "pull" the diff OUT of lock. If the incoming cables aren't pulling on the outgoing cable, the diff will be locked.
Spoonbill
Spoonbill
227
272
East TN
Adjust the cables under the bed.
You are a lifetime member, so you have access to how to adjust in the manual.
I upgraded my account to life membership last night but dont see where I can "see the manual". In any event, I looked at the video posted further down in the thread and it appears the center cable has pulled out of the tensioning mechanism. Any suggestions??
Neohio
Neohio
Beast of the East
21,712
92,794
Painesville Ohio
Can you share a picture?
Reactions: Remington
Jankyeye
Jankyeye
882
4,182
Tampa, Fl.
its in the "recourses" tab above
Reactions: Stevo and Remington
Spoonbill
Spoonbill
227
272
East TN
Here are a few pictures. The first one is the middle adjuster which apparently has been fatigued to the point where it separated from the cable to the rear diff. I don't know if I can simply buy this piece and recriminations to a fresh cut of the cable or if I must buy an entirely new cable and replace. Any idea if this can be done by a DIY mechanic like me or if I will need to take it in?
IMG 8167
IMG 8166
Neohio
Neohio
Beast of the East
21,712
92,794
Painesville Ohio
Replace the entire cable. Will end up being less work in the end.
Reactions: RacinJasonWV
