P1000 Turf mode
So I can tell the way the back wheels are pulling that it is in fact stuck in two wheel drive, even though the selector lever is in turf. Also the icon on the dash indicates two wheel lock. Any ideas??
Neohio
Neohio
Beast of the East
17,720
85,397
Painesville Ohio
Adjust the cables under the bed.
You are a lifetime member, so you have access to how to adjust in the manual.
Reactions: moparornocar
You are alifetime member, so you have access to how to adjust in the manual.
Thank you very much!
Reactions: trigger
Neohio
Neohio
Beast of the East
17,720
85,397
Painesville Ohio
Page 19-32 I was just looking it up for you.
Reactions: Montecresto
Do you refer to the owners manual in the glovebox, or something else.
Watch this video,
I am not sure if he is a member here or not, but he shows how to do it.
Soon as I get home I'll be making this adjustment!
Rodney960
21
21
South
How do you become a lifetime member?
pmward
pmward
136
303
Galena, Missouri
Monte, If you are still having trouble come time for Greeson, I will adjust for you.
dealer6
39
112
Hubbard
I'm having issues with mine also
But mine won't go into 2wd lock and the indicator lights for 4wd and lock aren't coming on but it is locking into 4wd
I have adjusted mine and sometimes I can get the 2wd light to come on
What do you guys think my issue is? Should I just take it into the dealer and have them mess with it? 06e7cc292c9455b09d59120b57b3f322
I know it's dirty in there right now
I've had it open for the past few hours trying to get the light to work
I did jack up one side and make sure it was in 2wd lock before I messed with the adjustments
ohiohunter
ohiohunter
103
141
Minerva Ohio
What do you guys think my issue is? Should I just take it into the dealer and have them mess with it?View attachment 53662
I'm having the same exact problem. Taking it to dealer Friday.
ohiohunter
ohiohunter
103
141
Minerva Ohio
Just cables stretching.. not hardly worth taking it to the dealer if you can't turn and wrench
It's been doing it since I got it. I worked on it for 2 hours last night. Seamed like an easy fix but will not go into 2wd and light will not come on now. I lined everything up as manual and the Neohio shows in video still didn't work, played with it some more to see if I can get the tension correct with no resolve. And it's not even as hard as turning a wrench, you can turn those nuts with your fingers. I already have it going in Friday for the heat fix issue anyway.
Reactions: JTW
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Sometimes they take a little tweaking. If i line mine up using the index lines mine wont work right either. To tight or too loose wont do...ita gotta be just so so....and it can be really aggravating getting it adjusted.
ohiohunter
ohiohunter
103
141
Minerva Ohio
I agree, it got to the point last night trying to adjust it with my 3 little ones climbing all over me and every time I started it they wanted to go for a ride. I gave up.
ohiohunter
ohiohunter
103
141
Minerva Ohio
There is some real good info in the thread
Park and 2wd lock adjustment
Thanks, I'll see if I have time of the next few days to run through it. It's sounding like after reading that I have the rear cable to tight now.
