Has anyone used one of these from UPI? If so, we’re did u mount it and how good or bad did it work?
I’d like to see pics of the install. I can’t imagine there being room under the hood on a 1000???did you get this sorted out? I installed the summit heater under hood and have part numbers for gates 1/2” to 5/8” inline adapters , gates molded hose to help with routing and a link to some amazon valves that will leak right after you put them in.
I agree Monte. I have too much stuff with a stereo amp, ground buss and a second battery to put it. I was going to put it under ther seat. Sorry I missed your post till today. I’m not getting the one at the top of the page. Either the summit of the Jeggs that has the venting kit with it. Looks close if not the same as the summit. Just ben bussy with work. Would like the gates numbers if u have them please. Do u have pics of your install? We’re kinda visual around hereI’d like to see pics of the install. I can’t imagine there being room under the hood on a 1000???
No worries about mud and water under the seat??I agree Monte. I have too much stuff with a stereo amp, ground buss and a second battery to put it. I was going to put it under ther seat. Sorry I missed your post till today. I’m not getting the one at the top of the page. Either the summit of the Jeggs that has the venting kit with it. Looks close if not the same as the summit. Just ben bussy with work. Would like the gates numbers if u have them please. Do u have pics of your install? We’re kinda visual around here
No. The Honda heater gets installed under the drivers seat. That’s where I was going to put it. It stays fairly dry in there. There’s no ALWAYS dry area in the machine unfortunately. If you have Skid plates like I do that helps aid in keeping it dry. Another thing to may consider when installing it there is to line the opening with some of that rubber roof membrane it a few small openings to help it breathe If you wish.No worries about mud and water under the seat??
In that location are you able to tap the systems cooling system lines right there under the seat, or do you have to run things forward under the hood. I have to say I’ve not looked under the seat of my 18 model 1000-5D (the one I keep in the Rockies and want a heater in) but under the seat of my 16 model 1000-3, it’s completely open, mud and water would be all in it. I can see how skids would provide some protection. Do you order an after market under seat storage bin or something to put it in? I’d like to see a pic of the one you’re using with something familiar next to it for size comparison...No. The Honda heater gets installed under the drivers seat. That’s where I was going to put it. It stays fairly dry in there. There’s no ALWAYS dry area in the machine unfortunately. If you have Skid plates like I do that helps aid in keeping it dry. Another thing to may consider when installing it there is to line the opening with some of that rubber roof membrane it a few small openings to help it breathe If you wish.
I think all the p1’s under the seat is the same. I don’t have that ridiculously expensive storage bin. I haven’t Installed the heater yet but from the looks of the Honda heater a friend has, you can splice into the hoses to the right (pssanger side) of that area easily. Like I said before, there’s not really anywhere your going to find that’s completely dry to put it. I just know that’s where a friend has his with no problems and I’m limited with all the stuff I have. That’s the only open spot I have and most logical for me at this point. I’ll find out more when I get the heater.In that location are you able to tap the systems cooling system lines right there under the seat, or do you have to run things forward under the hood. I have to say I’ve not looked under the seat of my 18 model 1000-5D (the one I keep in the Rockies and want a heater in) but under the seat of my 16 model 1000-3, it’s completely open, mud and water would be all in it. I can see how skids would provide some protection. Do you order an after market under seat storage bin or something to put it in? I’d like to see a pic of the one you’re using with something familiar next to it for size comparison...
Very well, I’ll stay tuned and appreciate you being the maverick on this so I can learn from your experiences. Have you seen that ridiculously expensive under seat bin? Do you think that the heater would even fit in it?I think all the p1’s under the seat is the same. I don’t have that ridiculously expensive storage bin. I haven’t Installed the heater yet but from the looks of the Honda heater a friend has, you can splice into the hoses to the right (pssanger side) of that area easily. Like I said before, there’s not really anywhere your going to find that’s completely dry to put it. I just know that’s where a friend has his with no problems and I’m limited with all the stuff I have. That’s the only open spot I have and most logical for me at this point. I’ll find out more when I get the heater.
Cool. Most of us already have dual batteries in that spot, does your intake cover still fit on ok?A little cut and paste and some tin bending for a bracket and it fit. I am a fit form and function kinda guy but if you wanted to you could tidy it up more then that
Looks great. But definitely would not fit with a duel battery and other mods under the hood. If you don’t wish to have those things under your hood your good to go.A little cut and paste and some tin bending for a bracket and it fit. I am a fit form and function kinda guy but if you wanted to you could tidy it up more then that
No I do NOT have that expensive under seat bin. It most deffenatly would NOT fit in there with it. So just forget about that bin. It’s a no go with a heaterVery well, I’ll stay tuned and appreciate you being the maverick on this so I can learn from your experiences. Have you seen that ridiculously expensive under seat bin? Do you think that the heater would even fit in it?
Hmmmm, that’s vulnerable. You need to do something about that no????No— there were some sacrifices. suppose i could reshape it and get it to go. it is close
Oh you could still have a dual battery if you ever do feel the need, several have put one under their seats.I carry an hd jumper pack everywhere i go so i didn’t feel the need for dual batteries. if i were more into the gadgets i would have used the under hood area for that and heater would have been floor mounted in front of middle seat. I wanted that area open for fishing gear.
