Mentioned it in the original thread https://hondasxs.com/threads/for-sale-rubber-noise-heat-shield.16406/#post-380153 but didn't want guys having to search so many pages or possibly missing it altogether. I didn't poke the drain holes in them for fear they might sag different in others machines and the holes would be in the wrong place.
Back when I was fine tuning the pattern, I made a new one for my machine. I didn't poke the drain holes in that one either as it hadn't gotten wet yet. I pressure washed it yesterday for the first time this year and pulled the seats today to check it out...
Rode tight trails pushing through limbs, a lot of wet sand and a few mud holes and this is what it caught from the top...
apparently stopped stuff from the bottom too, see the broken stick...
the water under the seat drains to the front and out through the seat bracket notches but behind the seat mine puddles in two areas...
found the lowest point in each one of them and cut in little holes about 1/4" to 3/8" round and the water drains out...
other than sticks, leaves and dirt I can leave the seats in and not worry about the Shield holding water.
For as little as it holds some may not even concern themselves with it but after using the carpet mat mod, one of my goals was that it never held water.
Thanks guys.
Thanks guys.
