P700 Voltage meter cosmetic question
jmanAZ
jmanAZ
57
50
tucson
I got my panel from Mystic and I'm starting to purchase my switches. I'm going to run the voltmeter/USB charger rocker style. I'm wierd about seeing lights on gauges and things sucking power when not needed. I'll have everything to the accessory switch on/off cable, but just curious who uses a switch to turn off/on their voltage meters. If yes, then curious why.
thanks in advance. I understand that it will only suck power while the machine is on so that's not the question.
thanks in advance
BHarris8753
BHarris8753
78
86
Robbins, NC
I ran my volt meter on anytime the key is on so i can monitor the battery voltage at any time so if a problem arose then id know before the battery was drained. The rocker switches i went with have a power indicator led on them that is powered ant time the key is on, not a huge fan of the light in the daylight, but night time is nice to be able to tell where the rockers are.
Dirtstiffs-1000
Dirtstiffs-1000
1,672
6,081
hondasxs.com
20200718 075134
No juice goes to any accessories from my 2nd battery unless one of these switches are on.
Reactions: jmanAZ and Mudwing
jmanAZ
jmanAZ
57
50
tucson
thanks
