P1000 Warn Axon 45S on a P1K with stock bumper?
Alphonse
Alphonse
15
41
LA (Lower Alabama)
Curious if anyone has installed one of these on a P1K with a stock bumper?
Did it fit okay? What adapter plate did you use? Any feedback?
Studying alternatives and looking for feedback on this one.
Warn axon
320,022
Those are so sweet! I like how simple they are to wire in, was wondering how long till someone pulled the trigger.
Like said above I’d have a hard time with under mounting on that it’s just too sexy to hide
Reactions: Ragnar406 and BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,560
14,609
Oshkosh, Wi
I like the design of this winch and the new 5500lb version is basically perfect for a P1k
Reactions: BWAF
Warn 93790 WARN Winch Mount Kit for Honda Pioneer 1000
For WARN PowerSports winches. This mount is compatible with both the small and large WARN bolt pattern, so it will accept all WARN ATV/UTV winches from 2000 - 5500 lbs. including all of the new VRX and AXON line of WARN Winches.
Moxie
Schuylkill
Does anyone have pictures of an Axon 45s/55s mounted on a P1K deluxe with stock bumper?
Reactions: sharp
Shooter63
Shooter63
Shooter 63
142
397
Longview
I have this winch on my 1000LE factory bumper and it fits with the warn mounting plate. It is hidden and you can’t see it but it is a bada** looking winch. Wish I could tell you how well it works but I haven’t had to use it yet. I will be in NW Arkansas in 2 weeks and I plan on trying it out.
Reactions: JSDAVIS and sharp
Shooter63
Shooter63
Shooter 63
142
397
Longview
Also this winch has 1 wire to hook up and the others are plug and play a monkey can wire it up it’s so easy
Superthrill
667
1,557
North Carolina
Sure you already know, but be sure and pick up a winch extension cable. The synthetic ones on Amazon are very reasonably priced. Even with a 50 ft extension, last trip it was almost to short to reach the closest tree.
sharp
sharp
3,757
14,955
Tennessee
I have the same winch with a warn mounting plate. Ill try to get a picture but there is really nothing to see except for a fairlead and the hook on the outside of the bumper. Just to give you a heads up before you go insane trying to get it to fit, the winch is designed to be mounted upside down on the rig. It seems strange but it works fine. Also there is not a wireless remote designed for it yet but the warn guy said it could be anyday now.
Maybe you realize and maybe you don’t... but the winch goes behind the stock bumper not on it.
Reactions: sharp
