Water in cluster
sspeederr
sspeederr
391
661
Anyone having issue with water in their meters
20201108 110209
5,019
22,394
Ewwwww, not yet. How new is it - warranty? 🤔
PaulF
PaulF
1,462
4,810
I have seen postings of a couple here and there. Some were condensation that Honda replaced under warranty but others were from submersion and Honda will not warranty those. The pic isn't very clear but that looks like more than just condensation, Honda may not warranty it.
If that display still works and Honda declines the warranty, you can remove about 6 screws and CAREFULLY split it apart and dry it all out and put it back together.
The cluster is vented on the back so if you are submerging your machine, you should plug all the vent holes on the back except one and then vent that one up higher so it doesn't happen again.
sspeederr
sspeederr
391
661
Machines 5month old and new cluster on the way machine hasn't been submerged the pic doesn't do it justice I honestly didn't notice it until half way threw day wife said it was soaked that morning I thought it was just dew but new one on the way so just wanted to see if others were seeing this if it was gonna be a common problem thanks for insite
5,019
22,394
Warranty or at your expense? How much are they?
sspeederr
sspeederr
391
661
Warranty didnt look up cost just ordered it
Reactions: CID
sspeederr
sspeederr
391
661
FYI meters retails at $130.00 I just hope the ecm is retaining the milage not the cluster
Reactions: CID
56,677
It's the cluster that retains the mileage on the Pioneer so I'd imagine it is the same on the Talon.
  • Angry
Reactions: sspeederr
sspeederr
sspeederr
391
661
Well p
Well plus side is i start over from 1000
  • Haha
Reactions: CID and Adam490
SpeedBuggy
SpeedBuggy
1,289
10,214
WA
I pressure wash my interior regularly and have not had any moisture issues. Do you keep it outside?
sspeederr
sspeederr
391
661
No I do the same presswash after every ride and garage kept
