BOX1
P500 WE SHOCKS ORDERED! Will I notice?
Steve00
Steve00
64
91
Florida
Walker Evan's shocks ordered with 1.5 inch wheel spacers and removing sway bar, Will I notice a difference on the whoops? There killing me at my atv park they dont groom the trails.
JCart
JCart
897
2,024
Kamloops, BC Canada.
You will not notice a difference...... please send them onto me.
Groom trails really? Snowmobile trail groomers here but UTV..nope. fact here we don’t have controlled UTV/ATV tracks (only closed course race loops). All our riding is done on public lands so far thankfully.
Have fun in the whoops, I’m guessing you’ll be 1-2 gears quicker.
j
25yrds
150
370
I'm envious! Counting on you to let me/us know how much improvement (there will definitely be improvement) you experience.
Todd627
Todd627
55,673
609,506
MI
How much did they set you back? Asking for a friend :cool:
HUCK
HUCK
1,047
2,314
ARIZONA
FREE SOLUTION ! SLOW DOWN
Reactions: Gassygordo
nctrailboss
nctrailboss
440
1,454
north carolina
YES.
nctrailboss
nctrailboss
440
1,454
north carolina
Just a heads up,,When you mount the fronts,with machine jacked up clear of the floor,spin your right front tire to make sure there is no binding in the axle at full droop.Mine did,it was a bump,bump,bump in the CV joint.I cut my lower shock mounts off and moved them 1/2" outwards on the A-arm.That was all it took to fix the binding.Turn the steering lock to lock while checking.The axle shaft is so short on that side.The left had no binding.Keep your spring pre-load light and the clicker out aways,and they give a great ride.
Boneanza
7
I Added the shocks without the spacers or disconnecting the sway bar... and still made a big difference! Enjoy!
Vondy
Vondy
1,381
8,749
Houston,OH
  1. Talon x4
I don't think I would own a P500 without WE shocks. They made a tremendous difference. Won't ride like a bigger machine, but still a huge improvement.
Steve00
Steve00
64
91
Florida
Well I got them hooked up remove sway bar added 1.5 in spacers tested amount today absolutely amazing ride so much better now when I hit the real deep whoops yeah it's still an issue but overall a 50% Improvement got to tell you no regrets all I have to do is figure out a good setup for my preloads does anyone have any idea what a good setup would be for the preloads I kept them as light as possible I'm just fear them bottoming out.
nctrailboss
nctrailboss
440
1,454
north carolina
Congrats on the WE's ! I'll try to measure where my preload is set tomorrow.Might give you a decent starting point.Don't be afraid to bottom them occasionally,You won't be using all of the wheel travel if they don't.Clickers can be turned in to help with the bottoming out.Did you check the right front for any binding in the CV joint?
Reactions: Arizona
150,968
Just set your ride height to what it was before the install, that's a good starting point. Then they'll settle and you'll have to adjust preload again, had to do that like 3 times with mine.
Reactions: nctrailboss
nctrailboss
nctrailboss
440
1,454
north carolina
I'm at 2 1/4" of thread showing on top with the fronts,1 1/8" in the rear.
BOX2
box3
