My 2016 P1000-3 has developed a complex. It has decided to go into weak mode rather than perform it's assigned task. It won't shift gears (I think it is 2nd), can't switch to manual and it bucks like a mule. All symptoms of weak mode, sick mode, safe mode... I am getting a DTC code of 52 which indicates the TR Sensor (Transmission Range Sensor) is reading high voltage and/or the Neutral Switch is stuck. So, my plan is to replace both. Sounded pretty straight forward to me, but....
First, I cannot find anything with the name Transmission Range Sensor for the Pioneer. Looked at a variety of OEM parts places. The only thing that comes close is a Sensor Assy (350 Degree) part number 38800-HL4-003 on the crankcase. Bike Bandit (and everyone else) is pretty proud of this part. I am hesitant to bite the bullet if this isn't the part needed. Anyone familiar with replacing this and is that the right part number?
Second, so the Neutral Switch was pretty easy to locate. Part number 35600-HN7-003. I looked at the schematics and it appears there are two of these. One for the front final gear and one for the rear final gear. Well, that was unexpected! So, is there really two of these? Maybe all the stay at home and social distancing has got my brain rattled. I just want to ride out there it no mans land! Is anyone familiar with the Neutral switch?
If I am way off base please let me know. I thought this was going to be easy but I have already spent more time trying to find the stuff than it will take me to switch it out.
