I am about to wire up ( dedicated wire to a rocker switch ) an led whip for the dunes. Do I need a relay? In general what Pioneer accessories would require a relay?
Would this work..
Rocker switch panel gets it power from the ignition-on wire as illustrated by Hondasxs
Blueseas fuse block ( see pic )wired directly to the pos side battery ( i already have neg bus bar installed)
Each fused output wire goes into a sep relay
The rocker switch triggers the relay only
Output side of the relay goes to the accessory.
Am I thinking about this correctly?
The relays in that box are the 30amp fuses but doesn't really matter that way. A relay simply turns things on/off so as long as you're not overpowering the relay you just match fuse.I assume the fuse size should match the relay size?
Looking at the listing on ebay, it no longer comes with the fuse. So like @CumminsPusher said you will want a circuit breaker.
