Yep, the good stuff normally is! LOL
Agreed
You've clearly never been to an Argentinian brothel! The beer cost more than the women!Yep, the good stuff normally is! LOL
Understood... but is the beer the good stuff?? LOLYou've clearly never been to an Argentinian brothel! The beer cost more than the women!
Straight from the horses tap!Understood... but is the beer the good stuff?? LOL
Depends on the amperage.. divide the wattage of the light (or whatever accessory) by the voltage (12) and if it's less that what your switch can handle.. which is usually about 20 amps. Then a relay isn't necessary I would fuse them all though.So if one was to run some rock lights, turn signals, maybe a light bar, back up lights, and a sound bar, do any of those items necessitate a fuse and relay center? Or will a simple fuse panel suffice?
pos tapes are nice I only use them in real tight spots cause they are so expensive but use these everywhere else also real nice and wont break the bank Hilitchi 140pcs 22-16 / 16-14 / 12-10 Gauge Quick Splice Wire Terminals and Fully Insulated Male Spade Wire Crimp Connectors SetThey are super easy to tap into existing harnesses as they don't require much slack in the wire..way worth it.
I like the negative block this comes with and they supply but connectors and shrink tube also mine didn't come with this stuff but it was also cheaper. Good linkI think alot of guys are using the PDM they sell on Ebay. It has a spot for 5 relayed circuits and 5 spots for non-relayed circuits. Everything is there so need to find a fuse panel or separate relays. I think it even comes with an inline fuse. It's a pretty good setup, but your above mentioned wiring sounds correct to me.
Universal Relay/ fuse auxiliary distribution box jeep, Cooper Bussmann Off Road | eBay
Wow! Lots of great info here so far! I just picked up my 1000-5 on saturday and have already started ordering my add-ons.
Are you guys using this Bussman in place of the OEM Switch Plate/Harness PCB? Or are you using this in addition to?
Here are my plans (and orders) thus far....not planning on much past this.
20" LED bar
Winch
Wiper
Horn
May eventually add rear facing lights and perhaps a bluetooth soundbar and CB radio. Nothing super extravagant planned. Should I return the switch plate setup and go this route with an alternative switch plate?
Thanks in advance for any suggestions! I look forward to many many years with my 1k5 and being a part of this community!
20" LED bar
Winch
Wiper
Horn
You get more storage space if you replace the safety decal, the Honda plate goes in the lower storage space under the space wasted for Honda to avoid lawyers that aren't theirs.
Ok, so then using this space with sort of switch plate and the Bussman previously mentioned, then there is no need for the Honda plate and wiring harness?
Also, are guys using a plate/switch setup or just removing the safety decal and cutting the holes for the switches in the dash?
Thanks!
