P700 What brand light bar?
Russ989
Russ989
22,642
147,257
Hey all, I’m getting my dual battery setup parts ordered and on their way but had a few questions about light bars. What brand do you guys use and have you had good luck with it? What’s the toughest that gives you the best bang for your buck? I’ve had a few nilight bars and they seemed to do fine but now that I’m building the 700-4 and plan on having it for a long time I wonder if I should spend a little extra $$. Thanks for all the input.
P
PolkaJoe
90
103
NEPA
I just wanted a small light up front because the headlights (converted to LED) still needed some help with punch for distance. I went with a 6” Rigid mounted between the two bars on the front bumper. I was originally put back by the silly price, but after reading multiple positive reviews about the quality and warranty I got the kit. The light output for a 6” was WAY more than I expected and so far the light is working without any issues after many deep swims ... no discoloration of lens, no fog at all and no dimming.
On the back of vehicle, I mounted some cheap LED floods from tractor supply company just so I don’t back in to a tree at night .... again. I mounted them high and reasonably protected, but I’m a realist, sooner later they will get hit with a branch or something and get busted or knocked off (at $20 each I won’t be upset).
Hope that helps.
Reactions: AlR
Rexter
Jacksonville, FL
That’s a loaded question...
Price/Quality/Economy/Size/Style/Ruggedness/Waterproof/Mounts/Electrical/Placement/Environment/Use and on and on
Reactions: ohanacreek
I would say:
Amazon special if you’re in a budget crunch. They work and are cheap to replace if they fail. Large and low output for size, I’ve had several “300” watt light bars that only drew maybe 100-120watts.
Rough Country if you’re an average joe, they are EXPONENTIALLY better than any Amazon special. I have a 20” single row and a pair of X5 cubes. 75% smaller for the light output vs a amazon special.
I had a 42” Dual row Amazon and the RC is far better.
MTN Lightbars if you have money to burn, they are 2-3 time brighter than an equally sized Rigid.
Russ989
Russ989
22,642
147,257
I would say:
Thanks for the info, I guess I should have clarified in my initial post. I am interested in what brands everyone is using but also is the extra money worth it. Sounds like the rough country will fit the bill.
Rexter
Jacksonville, FL
I have the Auxbeam brand. From my research they were a good bang for the buck. They are rated correctly. 120-watts is right on and maybe a tad over. You have to get creative when you start figuring out where to mount everything. Honda must have forgot to put that in the plan...
Russ989
Russ989
22,642
147,257
I’ve heard good things about auxbeam. I had a nilight on my last rig and for the money it was pretty great.
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Mine is a BLAZER.... It's been just fine for me...
IMG 0601
Reactions: Mudwing
MikeG
MikeG
359
2,478
Baton Rouge LA.
I have a 44” autofeel, it’s been on a year now with out any failures or moisture problems.
P
PolkaJoe
90
103
NEPA
Many people I ride with have auxbeam and like them and have had no issues I’m aware of.
Here’s the mounting I used and another of the output.
D94925f329ab3088a4808f8e084fe6fc32dd3cd37a685698980b19fa938a8dfb
K
kmitchl
Bought mine off ebay for $65 for 24". After 600 miles through some rough country still going strong and plenty of light.
2018_700-Deluxe
2018_700-Deluxe
Charlotte, North Carolina
Black Oak LED makes some high quality bars, for less $ than a comparable Rigid. I have one a 30" single row stealth mounted in the front bumper of my Tundra and couldn't be happier
For my Pioneer, i'm going with lights + pods from Arsenal Offroad. IP68 lights and good light output for a great price
P
PolkaJoe
90
103
NEPA
Sorry for the delay, it’s a 6” rigid single row driving pattern. I’ll find a photo.
P
PolkaJoe
90
103
NEPA
Cf04d0c44f0ec51a4d0324a4613c9c78Caee668a00330643e803954a22cd251d
(Photo taken in alley, sorry)
For reference, the trailer is about 40ft away.
First pic is headlights (LED upgrade) only. Second pic is headlights and 6” light on. 906613 is the rigid light number.
There is a small hill where the light stops, it does go further on flat terrain. But shown is what I consider “useful” lighting. Once the light goes way out it doesn’t really help for driving that much. People 2-3 ahead of me thank me for adding light for them at night LOL.
Reactions: swsebek
A
Average_Joe
951
3,534
Gainesville, Fl
  2. Other Brand
View attachment 97604View attachment 97605
Thank you, that little guy throws some light but it better at $280. I just ordered a Rough Country 8in for the front of my Nissan Titan single row for $79.99 license plate mount hopefully it's half as bright as that bar.
nbomar
nbomar
4,416
17,854
Springdale, AR
This is a great example of the focus and directed light output of the higher dollar bars. At 6” this is a lot of light! Now imagine how much light those 40-50” rigid bars throw. It’s crazy I can tell you!
LED and reflector quality along with correct alignment are KEY to a good beam.
People need look at the alignment of the LEDs in a Amazon special, they will be underwhelmed.
