105,995
I removed the battery cover and the horn and turn signals that never worked started working again!
Bad_bowtie
Bad_bowtie
Huge member
2,558
15,777
East Tennessee
@Bad_bowtie @trigger Can the PS be run off of the accessorie harness ?
White wire goes to the harness or other keyed on power source, Red goes to the battery positive and black to the frame for a ground. Then just plug into the control box.
0124182025
Reactions: rocmar and Chooglin
Mudder
Mudder
NTC/TAP Transition Member
11,727
88,913
Fyi. The ez steer unit motor I have listed a 220 watt max, so ran the motor lead off the winch supply line (6ga) previously added, and the ignition-on lead was connected to harness. Would not surprise me if they are all made by the same same place with different decales,...but as long as it works, no problem. Enjoy that one handed steering!
74F0B1EB 53A5 4CFB A8EE BC41B229F0CB 4C846DA2 06A2 4F11 931E 4BFCE217AC09
Bad_bowtie
Bad_bowtie
Huge member
2,558
15,777
East Tennessee
Sorry Choog, just saw this. I ran mine back to the power block, used up the accessory harness pretty quick. Why, you getting PS?
My accessory harness was also full, but I still used it. I used the plug that goes to the relay on my turn signals. I figured I don't use them much and they dont draw much power so it should be ok.
185,244
Not anytime soon but probably will eventually. I want to see how the 500 steering is after the locker install , then I will make a decidecision on PS !
My thought on the rear shocks, not anytime soon but probably will eventually. Like wheels and tires, you'd never go back to the stockers now. Most anything that makes it perform better is going to be high dollar, but worth it if you can...like the locker! :eek:
I
iceboundzeke
26
26
Iowa
Which lake were u fishing on Okoboji or big spirt ? Know
The area well . I run synthetic in all my machines haven’t
Had any issues , knock on wood!!
Little Emerson,Miller bay, big ice heaves so travel was limited.
185,244
Could say I got it for a number of reasons but mainly for hauling the pioneer in inclement weather, long distances and doing overnight stays.
7' x 12' plus the V nose, single axle w/7' interior height. One piece aluminum roof, stainless hardware and solid tube framing. Wasn't cheap and will have to sell some stuff to offset the cost but the way this trailer's built it will probably out live me.
Trailer 2 Trailer 1
rocmar
rocmar
4,741
5,776
4 CORNERS
View attachment 63136 View attachment 63137
Also...
been lookin...at same
trlr...the one we looked
at was...7'×15'...
White...outside lighting
& small tool box..on hitch
Reactions: trigger
Garbageman
Garbageman
54
224
Trigger, now you have to start accessorizing the trailer. Heater, bunk, lights, generator, tie downs, etc. Very nice, I thoght long and hard before i bought my open trailer.
Chooglin
What plans do you have for the inside of the trailer ?
Reactions: trigger
Mudder
Mudder
11,727
88,913
Could anyone with a 7 and 8.5 wide trailer post a pic with the P500 (and a person beside it) inside. Debating on width of trailer to get. Pic worth a thousand words, need to make sure I can get out if my waistline grows. Thanks.
Reactions: JCMINIS and 100Acre
rocmar
rocmar
4,741
5,776
4 CORNERS
Could anyone with a 7 and 8.5 wide trailer post a pic with the P500 inside. Debating on width of trailer to get. Thanks.
Your machine. ..stock is 50"
7'...= 84"...gives a little over a foot
..on each side..loaded..
IMO...
185,244
Don't plan to get too crazy with the creature comforts, just wanted a small rolling garage really. I have a bunch of glue, 18" x 18" commercial vinyl tile and black rubber base, saved from stores I've built, that I've kept around for a while. It's practically indestructible, easy to clean and will wear forever. Plan to prime, then paint the walls and ramp with some really good exterior paint. It has an insulated ceiling liner already in it. Figure I'll install a couple rubber protectors up the ramp to get some traction on. Hope to have it done by the takeover but weather will need to cooperate, can't just back it into the heated garage and it's too cold out for applying finishes.
Rustell
My toyhauler is 7' wide and I'm able to squirm out ok.. I usually load with the door held open with a bungee cord.
Ztrailer1
185,244
My toyhauler is 7' wide and I'm able to squirm out ok.. I usually load with the door held open with a bungee cord.View attachment 63212
Haven't even pulled into mine yet, want to do the floor before I start tracking dirt into it. The math says there will be plenty of room for the P5 and looking at your pic, that'll work for me.
Reactions: rocmar
iowaguy
iowaguy
624
1,425
Eastern Iowa
That would drive me nuts ,buying a new trailer and not being able to test it out!!
Reactions: trigger
