nitzo
I changed my axles yesterday, I went with the Rhino 2.0's. I took off the wheel, then the lower shock bolt, the tie rod, then the upper ball joint nut. All went well except getting that damn 19mm nut on the ball joint off, then worse, getting it back on and tight, there is like no room at all. What are ya'll using for this. I'm thinking maybe a really thin 19mm box end or something. IDK.
