P1000 Wheel alignment
ODAMO
ODAMO
1,283
3,450
Ohio
Has anyone measured the rear toe on a 1000 ? What should it be and what has been measured? Mine has about 3/8” total toe in. The front wheels were toed out about 5/8”. I set the front to be about 1/8”- 3/16” toe in per side and it seems to roll easier. The rear susp seems fairly stout but has no adjustability. I’m sure Honda felt on such a vehicle it’s just not necessary.
115,302
Yea the STOCK rear arms have always been a joke for camber and toe cuz of the no adjustability. Know matter what u do they will always be toed in at the top. The measurements will b different depending on tires as well. This is why a majority have bought aftermarket arms that allow camber adjustment, most popular being the SATV arms.
ODAMO
ODAMO
1,283
3,450
Ohio
JEEP just empty every pocket
BOAT bust out another thousand
PIONEER 1000 same as BOAT. Everything cost another 1000.
208,725
I set the toe in at 1/8 for both fronts combined, the camber isn't as easy, actually a pain in the butt, set shock sag with simulated riding weight, 1.5 inches, I used 80 lbs bags of Quick Crete and an ice chest full of trail pops. Then you can set the camber which is a pain with SATV arms. And by the way you need to do a center line to adjust the toe in / out on the rear as well. I measured the distance between arm bolt locations and used a couple of jack stands and pulled a center line. This takes some time, but do it or you will have one squirrly driving buggy.
