P500 Wheel spacers without PS?
41,754
How many are running front wheel spacers without power steering, and do you find the amount of kick back to be unacceptable? Please list the width as well.
I was planning on running 1.5's front 2.0 rear, but some comments recently make me wonder...
I know the kickback through the steering will be increased, but I figured it was a negligible amount, but now I'm not so sure. I do not have PS, and probably never will.
SouthwestORV
SouthwestORV
744
1,730
Taylor, Arizona
I saw @trigger mention that he installed Power Steering and spacers and of course now there is no issue. I installed the ITP steel wheels that have a slight offset to the outside, and while not bad, I can feel increased bump steer. I will be hesitant to put spacers up front on my ride.
156,311
Damn, why so wide? I would think 1" on the front and 1.5" on back would be plenty, even with 26's. Without PS you'll feel some bump steer but it's not terrible.
Reactions: DG Rider
41,754
Is that really that wide? Remember, I'm on stock rear wheels at all 4 corners.
My logic was that I am going up 2" in tire height, so I wanted to widen the machine and make it more stable than stock. That and realistically, the OEM tires are like 23.5's...if that.
But seriously, I am strongly considering 1/1.5" combo instead, and maybe a true 25" tire.
Reactions: trigger and 100Acre
41,754
what is bump steer?
Technically, it's changes in the steering geometry when the front tires cycle through suspension travel, causing changes in the direction the tires are pointed, having essentially the same effect as turning the steering wheel slightly. Usually only present on poorly designed lift kits these days.
BUT...what everyone here is referring to as "bump steer" is usually called kick-back. Imagine when your tire encounters a rock and attempts to "steer" the vehicle in that direction. You get feedback through steering wheel, usually is in the form of a jolt. The further you move the wheel assembly away from the steering knuckle, the more leverage you essentially give these objects to kick back through the steering wheel.
Reactions: trigger and tomcj2
RB3offroad
RB3offroad
1,702
4,752
Tempe, AZ
Widening the stance you will be happy with. so With your setup you could do 1 of 2 things that you should like
1 - 1" spacers on back
2 - 1" Spacer on Front 2" on back
But again its all about preference
103,533
I have the 5+2 off
SO, Bump Steer isn't the same thing as cow tipping then.....
NitroxDiver
NitroxDiver
488
918
Concord NC
I run 1” front 2” rear, stock wheels, 25” tires. The steering effort did not change by any noticeable amount and I did not see any increase in bump steer. I am very happy this combination.
41,754
I have the 5+2 off
Very clever.
Thanks for the input. Good to hear...
70Bones
70Bones
888
3,779
New Brunswick Canada
1" spacers all around, 26" tires, no power steering, and no noticeable change in steering feel at all. If I were to do it again, I'd buy 1" front and 1.5 rear spacers. However, quite happy with what I've got!
Rustneversleeps
Rustneversleeps
302
582
Talon,New Brunswick,Canada
I sure hope there is no bump steer i like to put 1.5" all around with 4 stock rear rims with 27" or 28-10-12.....or use the deluxe rims that i have which is 50" up front and 49" in the rear and maybe get 1.5" and 2.0" for the rear..
103,533
I’ve been slacking on installing the 1.5” spacers I got from @trigger on the rear and moving the 1” I currently have on the rears forward. Since going with the offset rims and 1” spacers on the rear, I didn’t not flop once at the Takeover. I can only imagine, that once I do the switcharoo, it’ll be as stable as can be. Currently all my efforts are going towards leaving for the west, prepping the trailer and Crunchy, plus maintaining farm stuff. The P5 is looking a little lonely sitting in the barn.
BCmedic85
19
WV
I’ve got 1.5 wheel spacers all the way around without power steering and haven’t noticed any significant difference in the handling or kick back in the steering than with stock.
NTCPrezJB
NTCPrezJB
President of #NTC
100,421
897,524
Canton, OH
I put 2" spacers on all four corners. Still stock tires/rims. No PS. No locker (not that it matters for this conversation). Sway bar still connected as well.
I was testing it to see what I really gained by doing full lock turns at slowly increasing speeds on flat field grass ground. I had the back end break loose (grass was high and folded over/packed down in the process so definitely some moisture assistance in making it slide out) after adding the spacers before I could get it to lift the inside tires. I'm not saying everyone should go this wide, but I like the extra margin of error for when I turn the controls over to the wife and kiddo.
