P1000 wheels offset
Y
Yotebuster
12
27
Oregon
New here did some reading cannot find answer to my question exactly I’m wanting to buy some aftermarket rims for my pioneer 1000 -3. SE edition. I want to run the same size tire front and rear which will be a 28 x 10 x 14 so if I bought a 14 x 7 wheel with a 5+2 offset do I have to buy wheel spacers for the rear to make the front and rear tires track the same I do not care about making my stance wider I just want the tires to track exactly the same and be able to rotate front to rear thanks for the info
Hillbillytnt
Hillbillytnt
517
1,897
Ky
Exactly is hard to get. Your fronts are 6.5 wide and rear are 8. Your wanting to go to a 7. I think you want as close as you can get.
PJon
PJon
760
3,055
Arizona
I have 14x7 5-2 all the way around with 28x10x14 tires. 1” spacers on the rear pretty much evens it out. If you use the spacers I’d recommend getting them from RB3 Offroad. They’re a little over 1” so you won’t have to grind off the studs and nuts to get a flush mount on the wheels.
Dusty 82
6
14
Ky
Welcome from Mississippi. I have a 2016 P1K-3 and I just added a 1 inch spacer on the rear to even it up. I have 28x9's up front and 28x11's in the rear, both on 5+2 wheels.
#NTC
Thinking about going with a setup similar to this how much wider did this make your front end? I would like to run skinny wide but with 5+2 front and 4+3 rear and no spacers.
Reactions: Lady01
PJon
PJon
760
3,055
Arizona
If you run 5-2 on all 4 corners with 1” wheel spacers on the rear, you’ll be able to rotate your tires. If you run 4-3 on the rear with no spacers, you’ll be about 1-1/2” narrower in the rear.
Reactions: Lady01
Dusty 82
6
14
Ky
Gotcha,thanks I’m just gonna go with 5-2 on all four.
105,354
Welcome from the Putrid Swamp Run Michigan!
What rig do u have that your putting these on?
PJon
PJon
760
3,055
Arizona
Sorry, I goofed up my calculations on that. You’d actually be about 1/2” wider in the rear.
Reactions: ChadD
Sjc3081
Sjc3081
263
442
Wappinger NY
I dont want my P1000 any wider. STI HD9 6+1 front and 5+2 rear. Keep factory width of 63”. Being able to rotate the tires is not worth the expense of spacers or excess bearing and suspension wear due to wider offset.
Reactions: ChadD
Dusty 82
6
14
Ky
8035C71F F15C 4BAF 9A48 24550104C349
105,354
I’ve done basic upgrades so far just trying decide on wheels and tires.Thinking about trying 28x9/11 terrahooks on factory wheels
Looks good man! Always liked the white. Thanks for posting.
If your all stock, and I know this isnt flashy as wheels. The first thing u should be doing is get rid of the factory “G” string skid plate and get yourself a full aftermarket skid. Also a snorkel kit. @Bayouownbeer sells a nice inexpensive kit. Trust me, if u think u need it or not, youll be glad u did! Would be a shame to have those nice wheels and messed up machine so u cant show them off! Use the search up top for skid plate options. Start a build thread with your progress as well.
Reactions: Rayger143 and ChadD
Bayouownbeer
Bayouownbeer
786
1,061
Chauvin LA
Thanks for recommending. Anyone interested send me PM.
