P500 Which offset do you prefer?
Ragincajun92
Ragincajun92
163
230
Kingsland, Georgia
What wheel offset do most of you guys prefer? I like the 4+3 over the 5+2 because my understand it makes the tires sit out a little wider which to me helps with these machine.
JayPo
JayPo
Somewhat Well-Known Member
14,377
135,825
Tennessee
I had 5+2 wheels with 1" spacers which is basically the same spacing as 4+3 wheels and no spacers. I think the width was around 54" or so. If I were to do it again I'd just get 4+3 wheels with no spacers.
Reactions: futzin
wvupsc
wvupsc
180
802
West Virginia
I have 5+2 offset and 1.5" spacers on all four corners. And I have 25" Kenda Bear Claw HTRs. Seems very stable... but I'm not worried about keeping a narrow stance for restricted 50" trails or loading in a truck bed. Stability was the primary factor for me. I wanted the smaller 520 to be able to thread thru tight trails in the woods, which it does well. The spacers and offsets don't limit my ability to drive those trails.
179,032
Same size tires and 5+2's on all four and 1" spacers for the back for an even track width. That'll put you at about 54". 4+3's will put you at about 56". Having ran about every width found that 54" is enough, it's stable. Went as high as 57", it was super stable but too wide for me. Was rubbing trees with the front tires and it just wasn't necessary. FWIW
Splorin
305
863
Maine
If looking at or running ITP rims the 4-3's are only a half inch more offset than the 5-2's for some reason. I think the steelies are the only 4-3's they offer nowadays but combined with front 5-2's is a good setup. My older Magnum 4-3's with 10" Mud Lites (9.75 wide) are just under 54". Wish I had 4 of those because the 2-5's with 12 wides in the back sure do find tree trunks and trail obstacles. And a huge push condition from the extra traction and width. I prefer the same size all the way around on a SXS as we're pretty much just drivin small 'jeeps'........
futzin
futzin
4,177
31,004
Kentucky
Just for giggles:
IMG 3208
