P1000 Which wheels?
Which wheel
  • Raceline Ryno beadlocks
  • STI HD beadlocks
Results are only viewable after voting.
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
What size are those tires? 30's they look Large!
Reactions: JTW
ToddACimer
ToddACimer
Pioneer 1005-2
3,746
15,862
Oshkosh, Wi
Fuuuuuuck.... you’re making this hard on me.
I looked all over for wheels and I had to have these. They are made for 12mm studs, they have the larger 5/16" bolts, they are double drilled so if you break bolts off you can clock the bead locks ring to the other set of 20 bolts. They look killer and they are load rated (1000lbs per wheel) for big machines like ours.
IMG 20180924 181633
IMG 20180924 181624
IMG 20180927 181628
IMG 20180927 181645
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
I was gunna bead seal... and I could use a small torque wrench.. just not sure what size I should get. I have a 1/2” but want something for the dirtbike and sxs.
I have a 3/8 for small stuff from harbor freight..think it starts a 5 ft lbs
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Anyone have any thoughts or suggestions before I order these? A better wheel for less or any issues with these I haven’t considered? My biggest “concern” are the smaller bolts compared to the HD9’s... thoughts?
@joeymt33 @Windrock1000 @snuffnwhisky @Hondasxs
@Or anyone else...
Those have a very strong beadlock ring.
Reactions: sharp and JTW
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Yeah, that’s why I wish they had the larger bolts. Why or how did you manage to break it?
Not sure..i think it had some junk in the threads..it felt weird but i cranked on it and it snapped..
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
I use anti seize on all my bead bolts. Also always used a cordless impact driver and cross tighten in 2-3 steps and go all the way around again. I havent had any leak. Depending on the wheel and tire bead thickness, some rings will tighten all the way to the rim.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Thoughts on the raceline rynos?
I like them. My mambas have been good. Extra set of beadlock holes in the rim is good. The HD beadlock ring is a lot tougher looking though.
Reactions: JTW
208,731
How did the gumies work out, the ones at the 18 Take Over/
208,731
Doing good. No plugs or leaks yet.
My Black Waters not so good, chunks taken out and a lot of tire wear from limited road use???? Still like the tire?????
Ahhh yeah. They actually charged me tax on my last order as well, stating that as of October 2018 they are required to charge tax nationally. I don't know how they are interpreting the law that way and Amazon isn't, but I bet it cost them a fair amount of business. I know that's one of the reasons I always shopped there.
So I noticed this as I was comparing the two... kinda pissed me off! I was about ready to commit to the raceline but now I’m mad and saying f*** it for tonight!
STI HD
C849BE5E B5E8 4DBC B7B3 41293F6A67AF
Raceline Ryno
433162B3 06B4 4B44 A99C 2DFB93643ED5
