P1000 White Lightning Build
snuffnwhisky submitted a new Garage Item:
Bought her 2 weeks ago. Had a full page s*** list the first night. Didn't really know about Honda having a sxs or much about sxs's until I talked to my brother about getting one. He works at the local Honda shop... lucky me! Started reading this forum after talking to him and out of the blue a guy at work wanted a four-wheeler and I had one... so it begins!
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
E brake finally underway. Had the disk and caliper mount done months ago. Just mounted the master. Going to go through the seat firewall for the handle.
View attachment 65322 View attachment 65323
You do really awesome work how long you been a machinist .I've been doing it 23 years. I don't do quite the job you do but i try. Nor do have such a sweet shop.
Sent from my SCH-R890 using Tapatalk
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
I just tinker. No professional here.
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
E brake works. Could use a smaller bore master cylinder for an easier pull. Think I have some old 4 wheeler rear brake masters I might try later. Still need to test this one some more and brake in the pads.
IMG 20180218 204348244
BWAF
BWAF
8,857
42,437
Carthage MO
I had thought about an electronic line lock but I like the idea if you blow a brake line you would still have ebrake
Reactions: sharp
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
The duty cycle is real low on the electric locks. The cheap manual locks like to leak and blow seals also. The stock master cylinder only has 1 shared reservoir so if anything leaks you will loose all brakes. Swapping to a dual reservoir master cylinder is what I would like to do also to separate front and rear brakes. Wilwood has a 1" bore master with remote reservoirs. Will have to fab an adapter bracket and rod. I'll get to that before takeover.
BWAF
BWAF
8,857
42,437
Carthage MO
I hadn't even looked at master cylinder yet . Something to think about. Thanks for info
Reactions: sharp
BWAF
BWAF
8,857
42,437
Carthage MO
I wonder with wilwood master cylinder if it would stop a little better?
Reactions: sharp
7,140
27,148
would a cable actuated caliper work? Similar to a Cadilac rear.
Any pics of the caliper/ disk mounted to pinion?
Or this?Screenshot 20180220 134629
Reactions: sharp and BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
Or this?View attachment 65708
I think somewhere like post 410 in this thread there was one way up there. I don't know why a cable wouldn't work might my be hard to pull unless you make foot
Reactions: sharp
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
The 1" bore would give a little more leverage than the stock 1 1/16" bore.
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
I bought the wilwood one just like that but it was not floating unless I made some crazy bracket for it. I wanted that with the old toyota truck pull and turn e brake.
7,140
27,148
Ok I did the Toyota pull Ebrake on my Rocky build. It worked flawless, but there' not as much room to work with here.
BWAF
BWAF
8,857
42,437
Carthage MO
I wonder how much work it would be to add a four-wheeler caliper to each Factory disc and then put the master cylinder on them or do cables with foot lever
Reactions: sharp
