P500 Who wants a diff. Lock ?
Seg
Seg
189
322
Notre-Dame de la Salette, Qc, Canada
Come on Mr Postman, don't let me hanging!!!
IMG 2049 IMG 2049
196,472
Seg
Seg
189
322
Now get to work :)
OK all done and rebuilt. I give myself 9/10. The locker operates has it should however I must have kinked the 4WD sensor cable or something. If I place the lever in 2WD, it still shows 4WD in the display. So I jacked up front and rear. In 2WD, only traction is sent to the rear and in 4WD, traction is sent to all 4. I can't think of a reason that the fact that the display is stuck in 4WD would have any adverse effect? Feedback anyone?
Reactions: Mudder and Chooglin
jmcampbell54
292
628
Texas
Is it pushed all the way in?
Chooglin
I would remove the clutch arm cover and make sure it is in fact returning to 2WD. Did you remember to put the spring back on the cable ? It could be that the arm has moved enough to disengage the 4wd but not enough to turn off the 2wd/4wd indicator
Seg
Seg
189
322
I'll do that (well tomorrow I'm done for the night) and yes the spring is there. The lever works and disengage 4WD based on my test when I jacked up the front and rear...
Chooglin
I'll do that and yes the spring is there. The lever works and disengage 4WD based on my test when I jacked up the front and rear...
Added a little more info/edit to my post
cardenas5810
5
US
Just installed my locker. I notice the front end clicks everytime i make a turn while on 4wd. Thats normal correct?
