P500 Winch Install Advice
ChrisO83
7
Park City, UT
Hello All,
I'm new to the P500 and I'm installing a SuperWinch Terra 25SR as a first time project.
I'm trying to find the best place to mount the solenoid so its close to the battery, in a relatively dry location and easy to get to; any recommendations?
Also, I'm hoping the circuit breaker will fit in the battery box with a little bit of coaxing.
Additionally, what is a good location to mount the remote socket plug? I thought the grill might be nice but I don't have the means to modify in a proper manner as I am in a remote location with limited tools and supplies.
Lastly, I might tap into the "accessory power socket" for power assuming it's a switch circuit, which wire is the hot?
Thanks for your help.
Reactions: Mudder
Chooglin
Mounted mine here
Screenshot 2018 04 06 21 08 19
Have a look at this thread for harness connections
P500 - Accessorry sub harness description
SpaceTroll
SpaceTroll
141
540
Kirbyville Tx
What Choog said. Mount everything up high under the hood and get the acc. harness to plug into
Reactions: Chooglin
Mudder
Mudder
NTC Ambassador of Walls
11,655
88,000
@ChrisO83 , consider mounting the breaker just outside the battery box, especially if it is a waterproof switched or resettable one. Nice to have access to turn it off when working on the downstream circuit. Avoid the PITA battery box cover. ROPS cross frame behind passenger seat worked for me. On the remote switch, Mounted on ROPS near where a side view mirror would be. Can reach the switch and still guide the cable back in during respool.
FF6D12B0 97F1 45B1 A70B BE42280FB91F
Reactions: DaddyDubbs
GRANITE
GRANITE
People Dying to come see me!
1,100
5,550
Brookville, Indiana
@ChrisO83, I'm doing a winch install myself. I have a good way of mounting that circuit breaker inside the battery box. I will take pictures tonight and post them here as well as where I mounted my solenoid under the hood.
