P1000 Winch Not Working......Some of the Time
nitzo
nitzo
521
1,105
East Coast, Florida
Okay ya'll another one of my questions. Most of you have seen my wiring set-up, pretty much the same as most dual battery ones, isolator, stinger, 100amp breaker, power to the winch is thru a 300a fuse then directly to battery. What its doing is, if I'm sitting at idle, both batteries tied together and hit the winch switch (the one on the dash) the winch will work for like 2 seconds and stop, this is without a load, I'll let off the switch for a second or two hit it again and it will go for another 2 seconds, almost like its reset or something then it will stop again. Now, if I push the throttle down, get the rpms up, it will pull and go all I want it to. What is taking place? Thanks
nitzo
nitzo
521
1,105
East Coast, Florida
I don't know, BUT you only need to wire the winch STRAIGHT to be batteries.
I get that, but I'm kinda a freak about wiring direct to a battery ( I know starters wire that way, but), the "whole" fire deal scares me, I figured I could put a 300 amp fuse in and it won't blow cause of load, but if something really goes wrong it will protect the machine from burning down.
wrhii
wrhii
302
1,758
Florida
Do you have a Volt meter? Is the voltage in the command function of the winch contactor dropping much below 11 volts at idle, Voltage may not be enough to keep the magnetic coils holding and just drop back out to neutral. Most contactors are noisy, after the 2 second run, can you hear the contactor click back out?
nitzo
nitzo
521
1,105
East Coast, Florida
I can hear it run then just stop.........what you are saying seems just like what it might be doing......I have of those dual voltage gauges and when it does it the second battery voltage drops to zero for like a second.
wrhii
wrhii
302
1,758
Florida
Can you easily find the small red wire running to the contactor and move it to the primary battery for kicks. and see what it does. Supply 12+volts to the command coils of the contactor. If its doing what we r talking about then the winch should run as normal. If it does then the next question would WHY the secondary is dropping voltage
BBLASER
159
277
Phoenix
Post up a picture of your wiring again. I know I've seen it before, but I think something may be seriously wrong if the secondary battery is dropping to zero momentarily. Have you tried looking at the isolator when you start winching and see if it disconnects the battery if you do not throttle it up. Maybe a dead cell in your secondary battery.
nitzo
nitzo
521
1,105
East Coast, Florida
New battery's both of them.
FuseWire
wrhii
wrhii
302
1,758
Florida
I haven't put a secondary batt or the isolator on so I'm out, but keep us up to date as to what you guys find.
BBLASER
159
277
Phoenix
Looks like pictures were taken at different times? Is that clear plastic the inline 300A fuse? I am thinking it is the contactor needing 12v and it dropping below that on idle. I do not understand why it would drop that low tho with no load on it.
nitzo
nitzo
521
1,105
East Coast, Florida
Yes, that is the fuse and it's #4cu wire so I'd think it's plenty big enough. I guess I'll make a new line directly from the winch to the battery and try that first. IDK.
Fuse
67,175
The one I have will disengage around 8 volts.
Where are you getting key-on power?
Reactions: BBLASER
BBLASER
159
277
Phoenix
I honestly think the 300a fuse has nothing to do with it not working. I think it is all in your winch contactor. There is really no reason a solid state fuse would cause it not to work. The part about watching your voltmeter on the 2nd battery hitting 0 is what puzzles me.
Jgroesbeck
Jgroesbeck
34
70
U.S.
I had a problem with a winch on a quad once. It came down to a poor splice job into one of the accessory wires. It would intermittently work or not work. Once I traced it back to a poor splice job it's been all good.
Reactions: Mudder and nitzo
Mudder
Mudder
NTC Ambassador of Walls
11,691
88,487
I understand the concern about a direct battery short, so installed my 300amp switched breaker just outside the battery box, then directly to winch. Did that just to protect downstream run inside machine. Your organized wiring is something to be proud of.
Reactions: nitzo and Mudwing
