Wondering what everyone is using and liking for a winch? My primary use will be plowing.
Thanks that is good to know. I do like simplicity!Warn Axon 45. The thing I like best about it is the setup. Positive and negative leads to power source and key on power wire. That’s all it takes to have it up and running. No solenoids to mess with. The rocker switch also comes with a plug instead of a five pin setup. Pretty much a plug and play system
Comes with everything you need including a rocker switch. Reviews can be read at the bottom.Anyone using the Viper Winch? Id like to hear some actual reviews. I like the price and the wireless remote option. Will i need to buy a rocker switch to put inside since it seems like all of these have a handle bar mounted switch?
Why is that? The rig is only ~1000lbs. I was thinking 3500 would be more than enough? Thanks - ChrisPersonally, I would not install a winch less than 4,500 lbs
I didn’t see you say what you are trying to winch, a pioneer 1K5 is ~1700 lbs before accessories for example. The winch rating is not even across the length of the pull and is only the max rating at the optimal cable wraps on the spool. So up sizing allows more flexibility/ pulling power without the need for snatch blocks. I did the Viper 6k wide spool on my P1K5. No issues, easy install.Why is that? The rig is only ~1000lbs. I was thinking 3500 would be more than enough? Thanks - Chris
The dealer installed a 3500 lb. in my Talon (I swear I was told 4500 but nothing was written down). The only time I needed it, the guy in front of me broke thru the snow crust, dropping into 4 tire sized holes. The 3500 couldn't pull hard enough to pull the tires thru the snow crust and I was below him, so pulling slightly downhill.I didn’t see you say what you are trying to winch, a pioneer 1K5 is ~1700 lbs before accessories for example. The winch rating is not even across the length of the pull and is only the max rating at the optimal cable wraps on the spool. So up sizing allows more flexibility/ pulling power without the need for snatch blocks. I did the Viper 6k wide spool on my P1K5. No issues, easy install.
Look in the manual. The weight is much more than that, then add the weight of fat girls and boys, beer and ice, then all the other stuff your adding and you'll be around 22 to 2400lb.s Then add the two other killers, up hill and mud. Double or almost triple everything. Read up on winch recovery. It's all a math formula about your weight, incline and how deep your buried as to how much force is required to pull your drunk ass out. And drunks never like to walk, kills the buzz.Why is that? The rig is only ~1000lbs. I was thinking 3500 would be more than enough? Thanks - Chris
Lol thanks. I have some knowledge on winches as my Jeep has one. Its not much more to go to a 4500lb winch so i will probably go ahead and go up one more step. You guys convinced me! Thanks for spending my money. Ha haLook in the manual. The weight is much more than that, then add the weight of fat girls and boys, beer and ice, then all the other stuff your adding and you'll be around 22 to 2400lb.s Then add the two other killers, up hill and mud. Double or almost triple everything. Read up on winch recovery. It's all a math formula about your weight, incline and how deep your buried as to how much force is required to pull your drunk ass out. And drunks never like to walk, kills the buzz.
Do not use a 3500. I have a 1000-5, I had the original logic of the machine weighs 1700lbs right? I doubled it and got a 3500. It's not enough. Also, my machine weighs 2200lbs with just me in it.Why is that? The rig is only ~1000lbs. I was thinking 3500 would be more than enough? Thanks - Chris
Thanks for the reply. It looks like you have a 1000. I have a 520.Do not use a 3500. I had the original logic of the machine weighs 1700lbs right? I doubled it and got a 3500. It's not enough. Also, my machine weighs 2200lbs with just me in it. Your machine does not weigh 1000.
