P1000 Wind from shifter
Strick9
7
Kansas
I got my foam from some packing for a product I received. I would suggest an upholstry shop. Sorry can not be more help.
Does the foam fit tight enough in the space to keep from moving around when you shift?
Hawk53
Hawk53
485
622
Alberta Canada
Push it in from top?
Yes. Size it up to cover the area. Put the shift lever in neutral position. Make a small slice so that the foam can be pushed over the lever. Using a flat tool work one side of the foam through the shift gate, them work the foam through the other side of the shift gate. Work the foam to spread it out in the area. Then using an olfa knife make a slice through the shifter gate where the lever will travel. If your foam sticks or is clinging to the shift lever try putting some silicone grease in the slot.
Skin0375
Skin0375
42
59
West Virginia
Friend of mine went too local AutoZone, purchased an aftermarket shifter boot, pulled the dash, installed the shifter boot, viola, fixed it. Looks factory, no air coming thru.
Reactions: Hawk53
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
Do you have a photo of this?
Skin0375
Skin0375
42
59
West Virginia
1st shifter boot install complete. Now too get another boot for the 4wd selector
20180216 171615 20180216 171622
strongbuilt
strongbuilt
260
606
That looks nice, need to do the both the 4x4 and the main shifter. I will be attemping this in the next few days. Just bought a honda soft cab and a bunch of rubber fasteners for sealing assistance, you'd be surprised how much cold air comes in through these shift holes.. thanks ohonda
Skin0375
Skin0375
42
59
West Virginia
How is the boot attached to the dash? Got any part #s and supplier info.
Not attached to the dash. It's long enough to simply tuck up under the edges around the shifter slot. No part numbers, just went to my local AutoZone and bought a shifter boot that's located in their accessories isle.
Reactions: Hawk53
T
Thamilt7
Wyoming
Take the shifter knob off .Move the lever to neutral position or in that area. Size up the foam and make a slice to slide the foam over the shift lever. Slice the rest after foam is in position. Well that's the way I did it anyway.
Just found this! I live in Wyoming and there is a tremendous amount of 0 degree air coming through that shifter hole. Your solution is super simple and definitely worth a try!
