Windrock1000
Have you had any issues with the setup. What is your second battery? I'm concerned that may yellow top is 4 x stronger (larger storage) than the stock battery. A lot of people believe they need to be same size and age! Your thoughts?I have my blue seas fuse box mounted where you have your ACR. After playing in mud and water on a recent ride I found, after inspection, that the drain holes filled with mud and it was holding about an inch of water. Solved the problem by drilling a few extra holes! Also used dielectric grease on connections.
Look forward to seeing it when finalized!
