Windrock1000
Windrock1000
2,539
9,663
Windrock, Tennessee
I have my blue seas fuse box mounted where you have your ACR. After playing in mud and water on a recent ride I found, after inspection, that the drain holes filled with mud and it was holding about an inch of water. Solved the problem by drilling a few extra holes! Also used dielectric grease on connections.
Look forward to seeing it when finalized!
Have you had any issues with the setup. What is your second battery? I'm concerned that may yellow top is 4 x stronger (larger storage) than the stock battery. A lot of people believe they need to be same size and age! Your thoughts?
Reactions: Eltobgi
sharp
sharp
3,757
14,955
Tennessee
They need to be the same size and age, they also need to be for offroad use so they can handle the beating it will take.
Reactions: joeymt33
Windrock1000
Windrock1000
2,539
9,663
Windrock, Tennessee
What happens if they are not the same size and Age?
Eltobgi
Eltobgi
4,599
15,186
North Dakota
No issues! I'm running the same system as you without the PDM. I run everything off the Yellowtop including winch! Just added another amplifier to my system and at idle everything looks good. Hopefully I can take her out this weekend and work her hard!
But...I've heard the same about adding a second battery when hooking it up in series same age, same size! I confident you will love it as much as I do!
Windrock1000
Windrock1000
2,539
9,663
Windrock, Tennessee
How low does you voltage drop when you got it all on? Mine is going from 13.9 to 13.3 when I turn on the 50" light bar. Thanks for your response.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Nowhere as clean as yours! I may clean it up when I slow down on my riding!
Reactions: Windrock1000
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Mine strts from 14.1 on both batteries. Primary holds constant without factory headlights and secondary runs about 13ish with party lights & stereo, blowers, rock lights. I will post after testing this weekend on usage.
Windrock1000
Windrock1000
2,539
9,663
Windrock, Tennessee
Cool. I will have mine complete tomorrow as long as my employees dont make me work. I'm shooting for a night ride Saturday night. I'm racing Sunday so Sunday's out for a day ride.
Reactions: CumminsPusher
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Lol! I hear ya! Don't forget the pics when your done! That stuff is like porn here! ;)
320,528
I'm about the same numbers as you Eltobi with the majors on. I know everyone says the same age, same size and same type but i think some of that goes out the window when they have an iso in between them. Even kills the connection between them while not running. They are actually getting charged separately in terms. Really shouldn't matter.
Sent from iPhone
320,528
I'm jealous of your real carbon fiber. Damn you! Looks great good idea with factory plastic clips as well. Doing great Windrock!
Windrock1000
Windrock1000
2,539
9,663
Windrock, Tennessee
Got enought to make two more panels if you would like a piece. It's hell to cut. Metal cutting cutoff wheel is recommended. Took 1.5 hours to cut out.
320,528
I'd absolutely love a piece but I'd have to rewire all the switches
Sent from iPhone
320,528
Are you really going to make me install that??
Sent from iPhone
Reactions: Eltobgi
320,528
Fine. Your right your right. I'll get back shortly thank you sir!
I'll need your address as well we might make a trade
Sent from iPhone
