First I wanted to thank everyone in here for the multitude of threads on this and all the helpful replies in them. I think at this point I have read every single post in each one of these. I am posting up below not only to ask for reassurance that I’m on the right track but also because hopefully if I am the below will be helpful to others in the future.
I currently have a 2021 Pioneer 1000-3 LE. I have (or am acquiring) the following items to install:
1. Odyssey PC925 second battery for accessories
2. True Battery isolator kit
3. Stinger 80amp isolator/relay
4. Buss 100amp circuit breaker
5. Blue Sea fuse box with cover
6. V series rocker switches for accessories
7. a relay for each accessory
8. The accessories themselves so far thats (52” light bar, Dome lights, stereo, rear lights, horn etc)
The questions that I have for those more savvy than I:
1. Any major issues in the layout I show below?
2. On the circuit breaker/stinger relay, should I switch their positions and put the circuit breaker first?
3. On the rocker switch, can I jumper pin 6 and 2, and just have the lights come on with the key on position?
4. This is a lot of stuff, in addition To what’s hear I also have a winch I’m installing directly to the accessory battery. I’m a bit worried about space inside the under hood compartment. Has anyone utilized the pre-aircleaner plastic case and just trimmed the fins off of it to make a mounting surface for the fuse box/relays? Part of me was also considering looking for Somewhere in the cab to mount this stuff as well. Open to suggestions
5. I’ve got some pretty low draw devices, usb chargers, dome lights, is it a bad idea to double them up on the fuse block? I only ask because if I can get away with a 6 circuit instead of needing a 12 that would make things a lot cleaner.
Thanks again everyone!
