P1000 Won’t stay running
Neohio
Neohio
Beast of the East
21,543
91,227
Painesville Ohio
Why do these break right there?
Bad crimp from factory. I took mine apart and the break was right at the crimp. I figure it was over crimped when the harness was built.
Reactions: sharp
Neohio
Neohio
Beast of the East
21,543
91,227
Painesville Ohio
You guys are awesome....
I get so much info from this site and if I can’t find what I’m looking for you guys are jumping into help.
Thanks for the help guys it’s really really greatly appreciated
If you need more room to work on replacing the connector. Remove the seat back. 5 10mm headed bolts and gives you so much more room to work. Also makes checking the air filter easier if you remove it.
Reactions: sharp and Werk
Werk
Werk
59
70
Florida
Gentlemen
Gentlemen
Gentlemen......
I finally had time to put the connector on the sxs.....
Well it didnt work!
I’m completely joking.
It worked like a charm and now I am up and running like it was brand new....
Thank you guys for all your help it’s greatly appreciated.
Mtoma
New York
I have a similar issue with a 2018 P1000D, the engine cuts out after the machine is warm. When it turns off the check engine light comes on 1 long and 2 short blinks. Any idea where to look? Thank you!
