P1000 Won’t stay running
Werk
Werk
59
70
Florida
Is this easy to replace or very expensive?
I have warranty but it’s not worth the months these geniuses will have it
Maybe a part number I need?
Is it simple or is a video that shows you how to replace?
67,665
Thanks @HondaTech
I happen to have picture of the rear injector wires just under the air box.
Also. I can hook u up with repair connector if needed. 2de0eef96fe1cbd39e4c0298265bda87
Reactions: JTW and Werk
67,665
That's where most break off at. Give them a snug pull. They should not pull out.
Reactions: Werk
HondaTech
I wish there was a sub harness for the engine on these. But the main harness is the only way to repair without splicing or repairing the connector.
Sounds like @Hondasxs has a way to replace the connector. I dont believe Honda sells just that connector for repair if its broken that close.
HondaTech
Thanks @HondaTech
Also. I can hook u up with repair connector if needed. View attachment 110364
I have the Transmission DTCs saved to my phone in OneDrive. I need to type up a PGM-FI list as well.
67,665
Anddd... that's why it will be a 1 month repair at the shop. No way I would allow them to replace the whole wire harness for that.
Anyways.
I just recently made a harness pigtail repair kit.
@HondaTech I know you cant use them at the shop. But if you ever need a few let me know!
HondaTech
Anyways.
Actually Honda would much rather pay us to repair a harness if it would save them money and us time. I've done harness repair before and had Honda pay for it.
We have access to a 2 pin male connector and then pins to fit, but I dont believe it us the same connector as this. I see the connector us available online as a "Honda fuel injector plug".
Thanks, I'll keep it in mind if we run into an issue. We have a few harnesses we steal plugs from now and then to fix stuff like this.
Reactions: JsheII3
Werk
Werk
59
70
Florida
Anyways.
How much for pig tail repair kit?
67,665
Sooo where did you guys go
Sorry.. had things to tend to. Lol.
Anyways. Here is a repair kit. Pioneer fuel injector wire repair kit.
Cut off wires, strip back and use the included posi-locks.
But I highly recommend soldering the wires if you know how.
Hope that fixes u up.
67,665
Wonder if it's from engine vibration.
I'll check mine tomorrow.
If the harness is secured to the frame that would sure do it.
Reactions: JTW
0860silverado
959
1,848
louisiana
I had the exact same problem on my '16 1-K. I fixed it with spade crimp-on terminals and heatshrink. Works like a champ! BTW, another member told me that an injector plug can be stripped from a CBR harness part # 32104-MJE-DOO
