P1000 Wont go over 13mph
mtrevino36
houston, Texas
I have a 2016 pioneer 1000 deluxe, it will not go over 13mph like it has some sort of limiter on it. I shifts fine and and accelerates just like normal then hits a wall at 13mph. I am at a loss and have no clue what else it can be. We have recently replaced both clutch assemblies, and oil pressure sensors It is not throwing any check engine lights. Has anyone else encountered this issue?
Reactions: BWAF
mtrevino36
houston, Texas
Yes and it doesnt have any wires going to the seat belt no seat belt light is on
Reactions: BWAF
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Can you shift it through all the gears in manual?
Reactions: BWAF
mtrevino36
houston, Texas
it shifts all the way to 4th then shifts back down to third due to lack of speed im assuming.
Reactions: BWAF
Neohio
Neohio
Beast of the East
14,590
73,875
Painesville Ohio
Send it back to the dealer that did the clutch update.
They left some of the wiring loose I would think.
Reactions: BWAF
mtrevino36
houston, Texas
Thanks for the help, It seems that the previous owner had a 2017 ECM in it. I just put a 2016 ECM in it and it seems to be working just as it should. Hopefully that fixed it. Thanks again
Reactions: BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,678
15,562
Oshkosh, Wi
Do you have the 2017 ECM? I'd be interested in buying it if the price was right.
Do you know if the machine remembered the previous mode AT/MT/sport like a 16 or 17?
donelec
Mariposa, CA
I have a new to me 2018 SXS doing the same thing. Did the EMC still fix this problem?
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Yours is most likely the seat belt switch, plugin or wiring to it. '16 did not have the seat belt switch so if you use a '17 and up ecu on a '16 machine you have to ground a pin on the ecu, reflash it to remove it or swap to a '16 ecu.
