P1000 Won't shift into reverse
samson7x
35
61
Arkansas
2016 with <100mi and it doesn't want to go into reverse. Display shows a dash "-" and that's it. I can shift to drive and everything works as normal, shift back to R and nothing. Confusing thing is if I do this a few times, it will eventually go into reverse however the display still reads "-"
Any ideas?
Reactions: BWAF
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Mine only does not go in reverse when it is cold.
Reactions: BWAF
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
You can check if the cable needs adjusting by shifting it down in a gear and instead of letting the shift handle fall in the gate, keep it pushed over and wiggle it up and down. It should be centered in the gate for each range.
Reactions: BWAF
hondabob
1,282
5,092
Prescott Valley, AZ
When in neutral it should be in the center of the gate. The cable adjuster is under the battery. There is an access panel under the battery. You may have a bad gear position sensor.
Reactions: BWAF
samson7x
35
61
Arkansas
I tried this yesterday and it looked to be center. If it was off, it wasn't by much at all.
If the sensor was bad, wouldn't it affect other gears as well? Forward and neutral work as they should and the dash reads properly. It's only in R that the dash reads "-"
Reactions: BWAF
Neohio
Neohio
Beast of the East
17,948
86,623
Painesville Ohio
Is your dash flashing any other codes?
I would suggest taking a video of the dash.
Start it. Wait for one bar on the dash for temp.
Go thru selecting gears until it has an issue.
From there, upload the video to youtube and paste the link here.
We will be able to better help you.
Reactions: BWAF
samson7x
35
61
Arkansas
Dash is not flashing a code.
Will try to get a vid tonight.
Reactions: BWAF
samson7x
35
61
Arkansas
Ok gents, I figured out what the problem was. I had some corn in the bed and discovered a significant hole in one that looked suspiciously like mouse teeth marks. I had a hunch so after investigating, the bastard chewed through 3 wires up under the drivers seat. After some splicing work, everything works as it should. I then set out many traps in an effort to avoid future frustration.
Thanks for all the help!
Marcpage
6
New-Brunswick
On witch one of the wire it was im having the same issue here sometimes it works and sometimes i have to play with it to make it work
