Looking for personal experience with those that have wood fired boilers.
We heat our home with wood through 2 wood stoves, one stand alone and one fireplace insert. Only other heat source in the house is electric baseboard, very pricey to run so it stays off unless we go away for a weekend.
Been toying with installing an outdoor boiler and running some hydronic baseboard through the house, thinking it could keep the wood processing down a bit. We go through 8-10 cords, and everything i burn now is split, moved, stacked, then moved inside daily. I've heard the outdoor boilers aren't so fussy about having wood split, plus I could split, stack and feed all in the same area.
Anyone know it they are worth it?
