I plan to add a couple LED cube lights. While I’m at it, I may as well bring some 6AWG with a breaker from the battery + to a fuse block under the hood.
Couple questions:
Are you guys using marine wire, or just good stranded copper?
Do you guys know the ring terminal size for the battery (+) post/bolt?
For relays, are you installing waterproof or just regular automotive relays?
Should I buy the 6 circuit Blue Seas fuse block W/ negative bus and just ground the (-) bus to the frame, or buy it without the (-) bus and run one (+) wire to the lights and ground each light to the frame?
Where is the best place to pick up the Honda accessory harness? Amazon is showing $21 for shipping.
Thinking about this light kit: https://www.amazon.com/dp/B06XW8WK6Q/?tag=sxsweb24-20
What clamps are you guys running for the rear work lights (mounted to ROPS near headrest)?
I’m sure I’ll think of more questions. Thanks in advance.
Couple questions:
