P500 Working on a exhaust silencer
Chooglin
This is as far as I got today , I should finish it up tomorrow.............this thing Is super quiet!
20170812 132840 20170812 132824 20170812 132900
Pay no attention to that bungy cord :)
Chooglin
Does it create much back pressure, thereby affecting power noticeably?
I figured someone would ask that , I really don't know yet ,because I haven't finished it yet.
The new pipe is larger than the stock exhaust tip , so I think it should be fine.I should know more some time tomorrow.
I
Ichybod
159
231
Tucson, Arizona
Now the burning question: If successful, will you be making them for the honda.sxs members? No pressure, mind you.
Reactions: Miss_Oak
luckymike
luckymike
144
322
michigan
Looks nice,small profile.is that a home made rear bumper?
Reactions: Miss_Oak
O
oldfortyfive
596
1,321
Illinois
So basically your adding an extended Tee to the tailpipe?
Reactions: rocmar
Chooglin
Ya pretty much ,I hope to post a video tomorrow to show how quiet it gets when you put the tube on!
I will most likely drill mutiple holes in the bottom of the tube to allow the exhaust to escape along with one hole drilled in each tailpipe
Reactions: rocmar
rocmar
rocmar
4,741
5,773
4 CORNERS
Nice mod...
props...to you
waiting on. The vid..
Reactions: Miss_Oak
rocmar
rocmar
4,741
5,773
4 CORNERS
I think I failed on this one , unless I can figure something out.
I drilled to many holes in the tube.........this thing sounds like a helicopter now.
STOP THE CAR....
your next mod....
ROTORY blades...
Reactions: Chooglin
rocmar
rocmar
4,741
5,773
4 CORNERS
Hang in there...bro
...ya learn way more....from
your fu-- ups....
than from your wins...
....you'll finger it out...
158,753
Keep trying Choog...thought I wanted an HMF to make mine sound BA but after hearing other machines, I'd rather go quiet. Preferably something that is just bolt on. ;)
Chooglin
I,m going to try something different, I think I screwed up by drilling holes in the tube and capping both ends of the tube.
158,753
Maybe bend those tubes back like a dual exhaust or do you think opening it up like that will make it louder? Would give it more air flow anyway?
Reactions: rocmar and Chooglin
Chooglin
I think it would be louder. If you take a straight tube (1 1/2 feet long) and just slide it over the stock muffler tailpipe, you won't believe how quiet it gets.
You obviously can't run it that way , but by making it 90 degrees to the tailpipe, you can.
I am going to make a new one and just cap the end closest to the tailpipe and leave the far end open!
Reactions: trigger and rocmar
Rustell
Years ago, when we would have to pass a sound test on our Enduro bikes, we would take a piece of a motorcycle inner tube and slide one end over the muffler.
